Author: Subject: megajolt
ady8077
posted on 12/3/06 at 08:30 PM Reply With Quote
megajolt
Hi all
soldered up board, all seemed to go ok, volt tests ok, is it best to clean the board to remove the flux? and do i need to coat it in anything?
Also need a box, any recomendations?
And i assume the comms lead is a standard serial cable?
Adrian
Mansfield
posted on 12/3/06 at 08:43 PM Reply With Quote
No help I'm afraid, but how much has it cost you? I have had a quote for a self assemble kit at £80.
paulf
posted on 12/3/06 at 08:54 PM Reply With Quote
Clean the board with some meths or similiar using an old toothbrush and then spray with a couple of coats of PCB lacquer.
For boxes I use the extruded ones sold by Maplins they are here http://www.maplin.co.uk/module.aspx?ModuleNo=33690&doy=12m3&QV=P
You do need to make some spacers to fit inside as the boards are imperial dimensions and all easily obtainable boxes are metric.
I cut the box down by about 6mm on the length also.
Paul.
wilkingj
posted on 12/3/06 at 08:56 PM Reply With Quote
As for the flux, it depends on what it is.
Some of the new flux's need to be washed off with water, you could test a small area of the board ie a non critical area, if you wash it with anything else!
Read whats on the solder reel label.
If the solder is more than a couple of years old, its probably OK, but this new crap needs to be dealt with, well the stuff I have does.
Best Regards
Geoff
http://www.v8viento.co.uk
paulf
posted on 12/3/06 at 08:57 PM Reply With Quote
For the comms lead you need a serial cable connected straight through ,as used for mouse extensions etc.I made a few for myself of various lengths , you need to connect pins 2, 3 and 5 only .
Paul.
ady8077
posted on 12/3/06 at 09:19 PM Reply With Quote
Cheers guys
The solder is quite old, it's not on a reel, no label
That box looks great, thanks Paul
Adrian
ady8077
posted on 12/3/06 at 09:29 PM Reply With Quote
Hi
Mines the old V 2 board, bought it months ago, I went halves with a mate and bought 2 kits from the states, it worked out about £100 all in, but then we got stung by the tax man
If you just order the board and chip from the states you shoul avoid import tax, the rest of the bits can be had from RS or farnell
Adrian
big_wasa
posted on 12/3/06 at 09:37 PM Reply With Quote
One of pauls up and running today
ady8077
posted on 13/3/06 at 07:57 PM Reply With Quote
Hi
Made a com lead, but can't connect to megajolt, it says com1 unknown serial port
I downloaded the software and copied the 3 files to java, and tried the hyperterminal test, but that doesn't work either
device manage shows com1 and i've tried uninstalling it
Anyway of testing the serial port?
Thanks Adrian
posted on 13/3/06 at 08:17 PM Reply With Quote
Originally posted by ady8077
Hi
Thanks Adrian
Suspect either your coms port is already in use for mouse or touch pad or you are using a PC which uses non-standard port address (Compaq are notorious for this).
BKLOCO
take it one step at a time.
Try the loopback test with hyper terminal straight out of the comm port. (jumper pins 2 & 3)
If thats ok then pug in your cable and try loopback on that (jumper pins 2 & 3 again)When thats working plug in your module.
[Edited on 13-3-06 by BKLOCO]
ady8077
posted on 13/3/06 at 08:43 PM Reply With Quote
Hi
I've never used the serial ports before, i cant find any programs that use them
whats a loopback test? i've looked on hyperterminal and it doesn't mention it?
Adrian
paulf
posted on 13/3/06 at 09:21 PM Reply With Quote
Have a look on the megajolt web site and find the self installing package on there . There is a post by pioneer x with a link to his website with it on .I have used it a number of times and it works perfectly.
Test your serial port with hyperterminal , there is lots of info on the megajolt site about it.
You could also try the new windows interface software on the megajolt site , I havent used it yet but it looks good.
Paul.
Hi
Thanks Adrian
ady8077
posted on 13/3/06 at 11:47 PM Reply With Quote
Working
I feel such an idiot, my computer case is marked wrong, the plug marked com1 is actually com2
Thanks for all your help
Adrian
