Author: Subject: Blanking off Dizzt when fitting MS ?
Major Stare
posted on 1/5/06 at 10:04 AM Reply With Quote
Just wondered what people have done/fitted when the Distributor has been removed on installing MS?
Jon "FISH"
Schrodinger
posted on 1/5/06 at 11:00 AM Reply With Quote
IIRC the dizzy still needs to be in place to drive the oil pump.
Fatgadget
posted on 1/5/06 at 11:33 AM Reply With Quote
You can safely remove a redudent dizzy off a Xflow.It's drive does not affect the oil pump unlike on a Pinto.
paulf
posted on 1/5/06 at 11:36 AM Reply With Quote
I turned up an alloy blanking plug with an O ring similiar to the distributor body and attached it with an oval plate secured with a screw at centre and the original monting point for the securing bracket.
Paul.
DarrenW
posted on 2/5/06 at 09:59 AM Reply With Quote
Sorry for the kind of hijack. What have people done when fitting megajolt etc to a pinto? Ive got a std dizzy that ive removed the balance weights etc out of and vut the top body off. This just leaves a shortened shaft sticking out. Does this need to be sealed off?
Ive seen the post where someone shortened in right down and fitted a sealed bearing on top but i dont have lather access so looking for a diy solution.
Darren.
