Author: Subject: fuel pump probs
graememk
posted on 14/5/06 at 01:38 PM Reply With Quote
fuel pump probs
i scarped the original ecu from my donor (nissan 1.8 turbo injection) as it was way to complex and i have a ms off paul, before i changed it over i'm sure my fuel pump used to run up to pressure then either slow down or cut out now id dosnt it just runs all the time...... is this correct ?
i know it needs to pump all the time but i feel sure it used to run then go quiet.
[Edited on 14/5/06 by graememk]
Danozeman
posted on 14/5/06 at 02:27 PM Reply With Quote
It will pump when the cars running but should only run when the engine off to prime the fuel system then stop..
Have u got a leak in the fuel system somewhere or a dodgey relief valve on the fuel rail??
Dan
graememk
posted on 14/5/06 at 06:23 PM Reply With Quote
so what tells the pump to stop pumping? is there a pressure switch in the submerged pump ?
paulf
posted on 14/5/06 at 08:16 PM Reply With Quote
It should run for about 2 seconds after turning on the ignition and then stop until the engine is turned by the starter motor.This is controlled by the megasquirt settings.
Paul.
zetec
posted on 14/5/06 at 09:47 PM Reply With Quote
The pump must stop if the engine stops or you will be in trouble if you have a smack and the fuel line is damaged...lots of fuel being pumped out with nowhere to go.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
