Author: Subject: Fuel hose
piddy
posted on 4/9/06 at 07:21 PM Reply With Quote
Fuel hose
I've used 8mm Micro bore for my fuel lines joined to components using gates 3225 hose which has a working pressure up to 1MPA.
I decided to re route a part of the line and went and brought some more hose but it's Codan hose with the following written on it "Fuel hose BSAU 108/2-L4/C4R & SAE J30 WP 12 bar" can anyone tell me that this is 100% suitable for fuel injection application?
theconrodkid
posted on 4/9/06 at 07:54 PM Reply With Quote
if it says fuel hose and 12 bar that is suficent for injection
who cares who wins
pass the pork pies
NeilP
posted on 4/9/06 at 07:55 PM Reply With Quote
From memory 1MPa is 10 Bar so 12 bar hose should be fine. Not many injection systems run over 10 bar - The Pacet pump I bought for mine is 7.5 bar max
posted on 4/9/06 at 10:45 PM Reply With Quote
1 bar is just under 15psi so you're looking at about 174psi so should cope with anything your pump can deliver.
piddy
posted on 5/9/06 at 02:08 PM Reply With Quote
Thanks chaps most appreciated
