Looking for a lightweight Denso/Kubota alternator. Not much second hand on eBay atm, so looking like it might need to be new. It's going on a
Zetec blacktop, and I already have an old style Raceline alternator bracket like this
I've noticed 2 on eBay from the sale seller. 1 is a 2 pin and 1 is a 3 pin. Can someone please confirm they are the correct type alternators,
whether they will fit the bracket I have, and if I need a 2 or 3 pin (I'm hopeless with electrics)?
3 pin for £80 delivered
https://www.ebay.co.uk/itm/Denso-Kubota-kit-car-race-car-light-weight-new-3-pin-40-amp-Alternator-2-8KG/114239669696?epid=1052142108&hash=item1a99
3705c0:g:htAAAOSwq3hexoY2
2 pin for £85 delivered
https://www.ebay.co.uk/itm/Denso-Kubota-kit-car-race-car-light-weight-new-2-pin-40-amp-Alternator-2-8KG/114231984511?epid=1052142108&hash=item1a98
c1c17f:g:lO0AAOSwvjVex4Sj
TIA
Starterman on here is probably the best choise for sourcing what you need. He was very helpful with mine.
J
I second starterman, it will come with the correct ribbed pulley etc on my silvertop i just needed to space it out a bit to line up with the bottom
pulley, but my bracket is different, so yours may fit straight on
Shooter
£72 all in with a ribbed pulley.
Yep, starterman was very helpful in supplying mine.
If you want to measure the distance between the lugs on your bracket I'm sure I can find you an alternative if you want.
Hi. Can you provide or PM me details please? Will it be the 2 or 3 pin model, which make and model, weight, and will it fit that alternator bracket. Many thanks
Whats the difference between the 2 and 3 pin?
The 2 pin is ignition and light feed
The 3 pin comes in Dummy, Ignition and light or Sense, Ignition and light, or com, ignition and light or Phase, ignition and light.
The choice is yours but choose the 2 pin, its easier to wire.
U2U me your address and email address and I'll send an invoice. Obviously I won't be able to send the unit until Monday, but I will send it
by TNT.
What pulley would you like fitted?
Done. The ribbed pulley please, to match the Zetec crank pulley.
Consider it done
