LOLOCOST LOOM
Ian Pearson - 24/5/03 at 09:47 AM
Anyone bought a pre-Vicki Green Lolocost Loom?
theconrodkid - 24/5/03 at 01:03 PM
word has it they are a bit pony,try premier wiring
Mr G - 24/5/03 at 08:08 PM
Yup gotta be a premier loom any day.
G
Peteff - 25/5/03 at 09:29 AM
You could try doing your own using the wire from your donor.
http://www.nfauto.co.uk/wiring_module.htm
These look interesting as well.
yours, Pete.
Ian Pearson - 25/5/03 at 10:30 AM
Hmmm...didn't give enough info, I'll sart again!!
Has anyone bought a pre Vicki Green Lolocost loom? The reason I ask, is that I bought one cheap at an open day, and I'm trying to sort out the steering column wiring. Nothing Pony about it, just that I know nothing about electrics!
Peteff - 25/5/03 at 04:36 PM
If its a sierra try reading further back in this topic. Lots of references to them.
yours, Pete.
macbrew - 30/5/03 at 07:10 PM
How much did you pay ?? Throw it away !
My mate bought Vicki Green loom and only had problems with the following :-
Lights
Ignition
Dizzi (big time)
Horn
Starter
Any thing else you can think of.
Cost him more time (and money) than doing it from scratch, which is my plan.
ChrisW - 30/5/03 at 09:40 PM
FYI I've used a mk4 Escort loom in mine. Fitted a treat, very few un-needed bits and even sits nice on the bulkhead.
Chris
Ian Pearson - 31/5/03 at 05:41 PM
Are you insane? Why on earth would I want to throw it away?? You must have your beer head on!!
I bought it cheaply to try and save myself some work. It was made by Autosparks, and should have come with a short adapter loom to connect up to a Sierra column. The adapter kit was missing which is presumably why it was cheap. £60.00 if I remember correctly. I have the loom installed in my car, and for the money, have no complaints. It's fairly straight forward, but as a non electrician, I was trying to make it "EASY" for myself.
I've spent ages going through the wiring diagrams, and think I've solved my problems.
macbrew - 1/6/03 at 02:12 PM
As far as I can see a pre Vikki Green loom is exactly the same as a Vikki Green loom, they just named it after her because she fitted it instead of her husband and rang Lolocost to thank them. Presumabely this was a rare happening for Lolocost so they named it after the only person that found it easy.
Sounds like we all need our better halves to fit the wiring loom.
theconrodkid - 1/6/03 at 05:09 PM
and we thought women were only good for 3 things
david walker - 3/6/03 at 10:12 PM
A friend of mine building a Locost bought one of these looms in an attempt to make it easier (quicker) for his auto-electrician friend to wire up his car. Having had a good look at it, the said auto electrician though it was OK as a source of different coloured wires but a joke as a wiring loom!
I'm not an electrician but wired my car up OK using the Mk2 Escort loom.
DaveFJ - 4/6/03 at 04:08 PM
so what are the other 2 things women are good for????????
theconrodkid - 4/6/03 at 05:31 PM
tin hat on dive for cover keep mouth shut and deny it was me that did anything ever
jonti - 4/6/03 at 07:51 PM
Quote:
[The adapter kit was missing which is presumably why it was cheap. £60.00 if I remember correctly.
_________________________________
The new 'complete?' (if RHE ever supply anything that's complete !) is only about £60 isn't it ? not that I'd give 'em 60p for one now !
The one I foolishly bought did just end up as source of wire
[Edited on 4/6/03 by jonti]
Ian Pearson - 4/6/03 at 09:36 PM
The VG loom is made in India I believe. The one I have was made in the UK by Autosparks.
Danozeman - 8/6/03 at 10:38 AM
Check where the wires go and what for in the loom and work out which wores out of your switches do what...
I think its easier to use the loom that came from your donor car. Its should be near enough plug and play with a bit of shortening within reason(although im nowhere near that stage yet)..
