Dolomite Tacho wiring
Chris Leonard - 8/12/03 at 01:01 PM
Can anyone advise how to wire it up?
I think one wire to the points side of the coil - what else?
Cheers Chris
Peteff - 8/12/03 at 01:58 PM
It should need a power in, an earth and a pass through from the coil to carry the impulses. That's the one you mentioned.
SeaBass - 8/12/03 at 02:01 PM
Case needs to be earthed. Lead from the coil to the bullet connection, switched feed to the 'lucar'. Thats how I wired mine.
Some early versions need to be wired in series with the coil as they use an inductive pickup.
