Author: Subject: H4 bulb male connectors
phelpsa
posted on 2/10/04 at 04:23 PM Reply With Quote
I have been looking for Male connetctors to go into the female connectors which plug onto the H4 bulb (if you know what I mean) I haven't found any. Anyone know where I could get some?
Adam
silex
posted on 2/10/04 at 05:53 PM Reply With Quote
Do you mean you want a 3 pin male connector that will plug into the normal female bulb connector on the hasness, or 3 seperate spade terminals that will fit the female connectons in the harness connector............Or have I got hold of the wrong end of the stick completely.
Murphy's 2 laws
1. If it can go wrong it will
2. In case of emergency - refer to rule 1.
posted on 2/10/04 at 07:17 PM Reply With Quote
For what purpose?
If you are extending the wires just cut them and put a piece in. The bulb has the male connector
[Edited on 2/10/04 by Peteff]
phelpsa
posted on 2/10/04 at 08:25 PM Reply With Quote
We have bought some lights for our Subaru, but they are designed for an STI which has and H3 for main beam and H1 for dipped beam. The WRX has an H4 bulb with both in one (if you get what I mean), so I need a male connector to replace the bulb to plug into the female end, which would normally plug straight onto the bulb. We cannot hard wire it in as this would void the warranty, they need to be removable to replace them with the normal lights.
Silex, I think you got the idea.
Adam
posted on 2/10/04 at 10:08 PM Reply With Quote
So what you want is 3 male spade connectors. You can use insulated female spades straight onto the bulb terminals. They just won't be in a block so you'll have to put them on individually but that's no problem. Something like this or a variation of it would do it. Rescued attachment wiring.jpg
phelpsa
posted on 3/10/04 at 07:57 AM Reply With Quote
That was what we were going to do if I couldn't find a connector, so I think we will do that.
Adam
phelpsa
posted on 3/10/04 at 08:35 AM Reply With Quote
Basicly, it wants to be like this:
phelpsa
posted on 3/10/04 at 08:36 AM Reply With Quote
But at the moment it is like this, with a connector which won't fit.
Adam
