Author: Subject: Well thats a little annoying...Stack tacho
furryeggs
posted on 4/8/17 at 11:50 AM Reply With Quote
I've had what I thought was an issue with my Stack ST200 Tacho's wiring. As soon as the ignition is on the back lights been permanently lit. As there are only 3 wire's +12v, 0v and ECU tacho driver there isn't a separate feed for the light.
I've emailed Stack to question the back light being on and they have said that's correct. The ST200 tacho has/is a permanently lit gauge.
I now have to drive around with 1 gauge permanently lit or my side lights on all the time to light the other gauges. Ok it's not a major issue but it is a little annoying, maybe I'm a bit OCD.
joneh
posted on 4/8/17 at 12:49 PM Reply With Quote
Nope - that would annoy me too!
loggyboy
posted on 4/8/17 at 12:57 PM Reply With Quote
dismantle/reassembly possible?
Mistral Motorsport
pekwah1
posted on 4/8/17 at 01:08 PM Reply With Quote
I hate to say it, but that should have been obvious if only 3 wires.... how would it know your lights are on otherwise?
But yes that would irritate the hell out of me too!
djaques
posted on 4/8/17 at 10:41 PM Reply With Quote
You could try 213 Performance in Bicester, they may be able to modify the gauge. They were able to repair my Elise Stack dash when no one else would touch it.
Angel Acevedo
posted on 5/8/17 at 04:52 AM Reply With Quote
Simple solution may be install a dimming pot?
Phil_1471
posted on 5/8/17 at 06:11 AM Reply With Quote
Connect the others up so they are permanently lit too...?
You can live in a car but can't rally a house
