Author: Subject: Side repeater position..?
foes
posted on 7/1/09 at 10:02 AM Reply With Quote
Is there any measurements needed (re SVA) as regards mounting my side repeaters? don't know wether to mount them in the scuttle or side panel?
cheers.
myeates
posted on 7/1/09 at 10:07 AM Reply With Quote
dont know about sva measurments but mine are mounted in scuttle about 1 inch up from where the scuttle meets the side panel and it passed without problems
thanks
[Edited on 7/1/09 by myeates]
Guinness
posted on 7/1/09 at 10:24 AM Reply With Quote
This was / is the section from the manual.
Light Angles
Light Angles
However, I think, there is an exception for 7's in the manual.
Mine are in the scuttle too BTW.
Mike
posted on 7/1/09 at 10:38 AM Reply With Quote
I put mine on the scuttle as most other MNR cars are but looking at many MK pictures they are on the side panels.
Personnal preference I would think.
smart51
posted on 7/1/09 at 11:32 AM Reply With Quote
Mine are on the scuttle. Mr SVA just seemed to look to see if they flashed.
andylancaster3000
posted on 7/1/09 at 11:57 AM Reply With Quote
I believe that there is a note somewhere in the SVA manual saying that 'seven' style vehicles are exempt from the repeater positioning rules or at least from the rear visibilty angles part anyway
Please correct me if I'm wrong however!
[Edited on 7/1/09 by andylancaster3000]
mad4x4
posted on 7/1/09 at 12:27 PM Reply With Quote
Scuttle for me as well.
Surely this help with them being seen from the front..... Wouldn't want them too low or you may have to move them up.......
[Edited on 7/101/09 by mad4x4]
Scot's do it better in Kilts.
twybrow
posted on 7/1/09 at 12:37 PM Reply With Quote
i thought the footnote for Seven type vehicles applies to cycle wing mounted indicators, which only need pass the field of view test in the straight ahead position.
posted on 7/1/09 at 12:46 PM Reply With Quote
Just mount them where it's easiest and they're clearly visible and you shouldn't have a problem at SVA.
Phil
JimSpencer
posted on 7/1/09 at 12:48 PM Reply With Quote
Slight thread hijack..
Side repeaters and MOT.
Can anybody confirm the following logic works:-
As i'm on a Q plate, and therfore tested as a 1975(?) car - which doesn't need side repeaters?
That I don't need them to pass an MOT?
neilj37
posted on 7/1/09 at 12:57 PM Reply With Quote
If its anything like it was for my TR6 if you have them fitted they may be tested and have to work. ie . Although my TR6 wasn't fitted with hazard light circuit because one had been retro fitted it formed part of the test.
Kriss
posted on 7/1/09 at 01:02 PM Reply With Quote
skuttle on my Indy - looks much nicer than side panel mounted to me
posted on 7/1/09 at 02:09 PM Reply With Quote
There is some latitude allowed as the side of the car is not the outside edge which is usually a line between the front and rear wings.
snapper
posted on 7/1/09 at 06:03 PM Reply With Quote
Only emmissions for SVA are tested to 1975 the rest of the car is tested to SVA pass date.
Side indicators for SVA on a 7 type kit are given a great deal of freedom but do need to be fitted.
Mine passed about 3" down from the bonnet side edge 4" over the exhaust manifold exit hole
I eat to survive
I drink to forget
