Author: Subject: Megajolt on a 5 cylinder car
RichardK
posted on 14/7/10 at 08:17 PM Reply With Quote
My MJ configurator only has 4, 6 and 8 cylinders as options, does anyone know if this is this editable for a 5 cylinder engine?
I'll drop by the autolabs site but Brent will probably be in bed know!
Rich
Gallery updated 11/01/2011
liam.mccaffrey
posted on 14/7/10 at 08:21 PM Reply With Quote
I think you might be disappointed, not 100% though
Build Blog
Build Photo Album
big_wasa
posted on 14/7/10 at 08:26 PM Reply With Quote
Nope megajolt just controls the edis and they didnt do a 5 pot edis
RichardK
posted on 14/7/10 at 08:38 PM Reply With Quote
shame, been offered an st225 for not alot of money and I would enjoyed putting together a set of carbs etc, get the feeling though the bellhousing might have been a problem though so maybe a lucky escape, engine was in a small fire and the ecu/wiring isn't available either, hence the MJ and carb route.
Would have been fun until things went wrong
Rich
liam.mccaffrey
posted on 14/7/10 at 09:06 PM Reply With Quote
Its only a T5 volvo whiteblock engine, both mine cost less than 100 pounds each.
You could probably pick up a whole donor for not much more than that.
Build Blog
Build Photo Album
Fatgadget
posted on 14/7/10 at 09:13 PM Reply With Quote
How about using a six pot edis? Rally Audi quattros used 6 pot kugelfischer injection pumps, the other outlet being simply blanked off.Cant be any different with a MS.
RichardK
posted on 14/7/10 at 09:44 PM Reply With Quote
Was thinking about an edis6 but I'm not the luckiest of people generally so its all bound to go wrong, tend to leave the pioneering stuff to them with more brains and money than I
Thanks all
Night Night sweet dreams!
Rich
robocog
posted on 14/7/10 at 09:51 PM Reply With Quote
Not been on the megajolt forum for a while but there were roumours of an edis less setup being developed at one time
Regards
Rob
robocog
posted on 14/7/10 at 09:58 PM Reply With Quote
http://www.autosportlabs.net/Megajolt2#Megajolt.2FCOP
I'm guessing 5 cyls just wont work as wasted spark and will be a bit limiting
but it looks like he's going to /eventually/ do a coil on plug unit that looks like it wont suffer from even cyl count only limitation (just says up to 8 cyls)
Failing that megasquirt would also fit the bill and should work with COP systems
Regards
Rob
[Edited on 14/7/10 by robocog]
RichardK
posted on 14/7/10 at 10:10 PM Reply With Quote
Thanks for that Rob, how did you get -207 posts
Rich
robocog
posted on 14/7/10 at 11:27 PM Reply With Quote
LOL,
I /very/ unsucesfully flounced
Pronounced myself out
Realized its only the internet (see image below)
Re joined, did some convenient pruning to hide my failed flounce and some inane ramblings and ended up with a minus posting count
Only 206 more posts and my flounce will finally be a skeleton in my closet
duty calls
duty calls
Regards
Rob
RichardK
posted on 15/7/10 at 07:09 AM Reply With Quote
LOL
Taka care mate
Rich
posted on 15/7/10 at 01:45 PM Reply With Quote
It's very different with MS. Injection timing (i.e. start of injection time rather than duration) is non-critical. The engine will run whether you inject against a closed or open valve. With an ignition system the timing needs to be accurate. An EDIS 6 will generate a spark every 120 crank degrees, but a 5 cylinder engine needs one every 144 degrees.
