Author: Subject: installing digidash1Lite
RK
posted on 17/9/10 at 01:56 AM Reply With Quote
Just received from D. Tweeks. I feel very odd saying this, but I just can't face it. I did all my own work wiring the car, with a lot of trial and error.
In your country, how much do you think it would cost to have an auto electrician or mechanic install the sensors, magnets, wires etc ?
Just a question.
I have one autoslalom and one trackday left in the year, and I want to drive, not rush about fiddling with the car. I am not in a hurry to install the new bits, but the longer I go without driving it, the less I want to wrench on it!
interestedparty
posted on 17/9/10 at 05:19 AM Reply With Quote
If all you have to do is the install the dash and the sensors, then I think it would be quicker to do it yourself than to find someone else, explain to them what to do, then get them to actually do it.
It won't be that hard, really. You need to stimulate an attitude change. Correct choice of music does that for me, the Beatles are especially good, work your way through the albums chronologically and by the time you get to Abbey Road you should have it sorted
Mal
posted on 17/9/10 at 07:12 AM Reply With Quote
If you have wired all of your car then installing DD2 will be easy. I have done both things, so think I am qualified to say. The wiring diagram gives you most of the information you need.
If you have any problems contact ETB instruments, who are very helpful.
HTH
Mal
blakep82
posted on 17/9/10 at 09:16 AM Reply With Quote
about £30 per hour normally i think
________________________
Chet
posted on 17/9/10 at 11:35 AM Reply With Quote
FYI-
The ETB Digidash lite is a great unit. I strongly suggest you consider installing it yourself.
The documentation on the wiring diagram and the manual on the CD will cover most any questions you may have.
You may want to consider using the GPS add on to even eliminate the need for the magnets.
The unit comes with it's own sensors so you don't need to worry about that issue.
RK
posted on 17/9/10 at 05:37 PM Reply With Quote
Thanks, people. I will start with
Abba and end up at ZZTop.
The softwear DigiTools, it comes with, is very unclear as well. After I put gear ratios in, I was totally lost. Also setting up the unit itself involves going through the different display possibilities, leaving me aghast. Not keen on phoning the UK to sort it out either.
Would JB Weld work for gluing the magnets? Still not sure what they mean by "dimple down" and "install both". Can't visualise that part. The magnets are TINY.
interestedparty
posted on 17/9/10 at 05:57 PM Reply With Quote
Good quality slow setting epoxy (araldite in the UK) works well, as long as everything is clean (cellulose thinners is good). Warming the epoxy with a hairdryer will make it easier to use, and drive the micro-bubbles out (It will go translucent)
Magnets should have one side marked with a dimple, so glue them with that face down. Use both I assume means mount both of them 180 degrees to each other.
RK
posted on 17/9/10 at 10:28 PM Reply With Quote
I have emailed ETB. It is premature to try to help me further at this point. Thank you everyone!!
