Author: Subject: ford flasher relay
beaver34
posted on 9/11/10 at 08:07 AM Reply With Quote
ford flasher relay
hi
i have a ford flasher relay im and wanting to know what the connect where, its a 3 pin unit the numbers are that are on it
49aL
31- 49+
Stott
posted on 9/11/10 at 08:12 AM Reply With Quote
On mine with mk1 stalks it's 49 to column plug terminal 49, 49a to column plug terminal 49a and the 3rd to earth.
HTH
Stott
EDIT: alternatively if you aren't using the sierra stalks then just take the live feed to your indicators/hazzards through pins 49 &49a and then earth 31
[Edited on 9/11/10 by Stott]
posted on 9/11/10 at 10:10 AM Reply With Quote
49 is from a 12v power source, 49a to the switch which swaps from right to left and 31 1s earth
Madinventions
posted on 9/11/10 at 11:24 AM Reply With Quote
From the CBS catalogue:
DIN terminal designations
Ed.
View my band website:
http://www.shadowlight.org.uk
