Author: Subject: Progress Pics -Rear Lights
big-vee-twin
posted on 22/11/10 at 12:14 PM Reply With Quote
Got my rear lights installed and wired over the weekend, starting to look at bit more like a car now.
They are from SVC the Hella mix and match, LED tail and stop outer ring with conventional indicator inner. Fog and Reverse with outer ring reflectors and conventional inners.
Rear Lights fitted
Rear Lights fitted
http://www.triangleltd.com
omega 24 v6
posted on 22/11/10 at 12:19 PM Reply With Quote
Looks nice and sorry to say this but your reflectors are/will be illegal for IVA. They should be no more than 400 from the outermost part of the vehicle. A set of stick on ones will do the job though.
big-vee-twin
posted on 22/11/10 at 12:23 PM Reply With Quote
They are less than 400mm from the edge 395mm to be exact
adithorp
..and is the lens of the fog light vertical? Almost vertical isn't good enough for IVA.
http://jpsc.org.uk/forum/
big-vee-twin
posted on 22/11/10 at 12:25 PM Reply With Quote
Yes vertical, the back is up on stands so looks like back is angled
omega 24 v6
posted on 22/11/10 at 12:34 PM Reply With Quote
Good then its spot on well done ( same lights as mine)
