Author: Subject: help how to keep condensation free ???
INDY BIRD
posted on 12/1/11 at 09:55 PM Reply With Quote
Hi all
went in the garage tonigh and it was damper than ever and its ticking me off, mnr will start to rust if this continues oh and the chrome on the new harley will be affected,
may get a bubble for the bike but any other ideas, its a big double garage not attached so will prob cost a fortune to heat,
any ideas welcome of course in the tradition ideally locost
cheers all
dilley
posted on 12/1/11 at 09:59 PM Reply With Quote
2 tonnes of salt....that will absorb it!
flak monkey
posted on 12/1/11 at 10:02 PM Reply With Quote
Keep the inside temp warmer than the outside temp and allow some ventilation. Its the only way to properly stop damp.
A couple of trays of salt will help too, but if its veyr damp they'll need changing regularly.
Sera
http://www.motosera.com
INDY BIRD
only 2 tonnes ?
hows it going mr diley hope the buggy is going well?
its not really really bad, just the hole bike was covered in condensation and i have spent the evening cleaning it all off and trying to heat up tha garage to clear it all,
so may look at vents in the windows etc if that will help??
cheers
[Edited on 12/1/11 by INDY BIRD]
big-vee-twin
posted on 12/1/11 at 10:10 PM Reply With Quote
I use an oil product from Scotoiler to spray on my chromework which protects from road grime and condensation in winter, easily washes off too, works well.
May help until you get the vent sorted out.
http://www.triangleltd.com
dilley
posted on 12/1/11 at 10:11 PM Reply With Quote
Nearly done mate! been out for a drive although we are still trying to resolve the mystery running issue!
dilley
posted on 12/1/11 at 10:12 PM Reply With Quote
Leave the window open on trickle?
MikeR
posted on 12/1/11 at 10:20 PM Reply With Quote
Make sure the garage 'breaths'. Lots of gaps will let lots of air circulate and you'll get no damp. A sealed garage (like a sealed loft) will get damp.
zilspeed
posted on 12/1/11 at 10:34 PM Reply With Quote
Lotssssss of ventilation.
If you can't heat it, have loads of ventilation.
RazMan
posted on 12/1/11 at 11:09 PM Reply With Quote
As said, ventilation is your best bet. You might try an electric oil filled radiator on really low setting - it might help a little during the wettest months.
Raz
loggyboy
posted on 12/1/11 at 11:20 PM Reply With Quote
If its condensation then it must have some temperature. Try a basic dehumidifier, parents have one in the home works well, also gives an endless supply of ionised water, lime free, great for the wifes steam Iron if you live in a hardwater area.
jwallbank
posted on 12/1/11 at 11:48 PM Reply With Quote
Ventilation has worked for me. Keeping with the locost theme I used a fan from an old desktop computer power supply - they run on 12v, quiet and are long life - I cut a 3" hole in the wall and mounted it on the inside like an extractor fan. You can leave them running permanently. Ran initially from a 12v battery but later used a 12v power supply from a dead rechargeable torch. Works a treat, my build which has been on the go for 5 years now and the fan is still going strong. Don't have any heating on except when I'm in there working.
RazMan
posted on 12/1/11 at 11:51 PM Reply With Quote
You have HEAT in you garage??? I just have a woolly hat
eeeeeee by gum .... luxury
Raz
snapper
posted on 13/1/11 at 06:22 AM Reply With Quote
Ventilation in this instance will not help, our barn was very damp yesterday and has natural ventilation through big gaps in the doors and through cracks in the Walls.
It's been very misty lately so the air is full of water the only way to prevent this is to heat the space above the dew point which I think is 12 degrees.
For you Steve I think only a big inflated car bubble will keep it dry
I eat to survive
I drink to forget
snapper
posted on 13/1/11 at 06:36 AM Reply With Quote
A bit more research shows that condensation occures closer to the current air temperature the more humid the air is so the recent problem is due to the high humidity/mist we had yesterday.
If the material is hotter than the air, water will not condensate out of the air on to the surface, yesterday the air temp was 12 C so the car would have to be hotter than that, most other days the difference between dew point and air temp could be as much as 20 C
No fixed temperature to aim for but in general a misty day will mean condensation, covering the car may help to reduce the issue
I eat to survive
I drink to forget
Irony
posted on 13/1/11 at 08:16 AM Reply With Quote
I suffer with this problem as well. My garage is okay but I started using a butane gas heater and that just kicks out water. The only way I have found is a proper stove burning wood or coal. Or a dehumidifier. I now have both and the garage is dry as bones. The dehumidifier is cool. It came from B@Q and cost £80.
ed1801
posted on 13/1/11 at 08:24 AM Reply With Quote
For winter on my bike I use ACF 50 spray stuff. cover the whole thing with this and then wash it off in spring. It does come off easily when washing and protects against water and salt. My bike has now ridden through 12 salty winters - and there is no rust on it whatsoever. Shame that everything else about it is knackered.
Bluemoon
posted on 13/1/11 at 09:33 AM Reply With Quote
Ventilation simples.. I have had some issues take a look at this thread:
linky
Still there but ventilation has helped a lot in my case it's damp rising from the floor....
Dan
matt_gsxr
posted on 13/1/11 at 10:01 AM Reply With Quote
You have a garage, I dream of a woolly hat
posted on 13/1/11 at 06:18 PM Reply With Quote
problem also arises when the garage has filled up with moist air during the day, as it cools at night the moist air deposits the water, as it cannot hold it all when cold - similar concept to why it rains. Also, large lumps of metal get very cold overnight and then, during the day, they get condensed on again.
So, insulation also helps because it reduces how much the temp changes, both of the air and the items in the garage.
You need to experiment, try a 100w old style bulb on constantly, and a dehumidifier, and ventilation, and see which works for you.
snapper
posted on 13/1/11 at 09:12 PM Reply With Quote
This shows the problem we have in trying to combat condensation in a garage
I eat to survive
I drink to forget
