Author: Subject: What do I need for replacing wheel bearing
SeanStone
posted on 17/1/11 at 05:36 PM Reply With Quote
I've been replacing the studs on my rover and I will most likely need to replace the wheel bearing in the process.
I've looked it up and it seems I have 2 options.
The first being http://www.allcarsallparts.co.uk/product_details.php?productID=133264
And the second being http://www.allcarsallparts.co.uk/product_details.php?productID=143411
Which do I actually need to get? Obviously there is a big difference in price, but having not done this before I don't know which is necessary!
Apologies for my negligence as this is a very simple job to some, but hey, we have to start somewhere
jwallbank
posted on 17/1/11 at 06:12 PM Reply With Quote
Looks like the difference in the kits is whether or not you have ABS. If you've got ABS it's the dear one!!! I guess with ABS the bearing is sealed in the hub and can't be replaced separately so you have to buy the whole hub assembly. So, check if you have ABS.
SeanStone
posted on 17/1/11 at 06:16 PM Reply With Quote
Oh goodie.....
thunderace
you need a press if your going to fit them
heres a link showing you how to fit them
http://www.youtube.com/user/scottykilmer#p/search/0/OeSykJguOjY
posted on 17/1/11 at 06:46 PM Reply With Quote
Difference is one is for the Front the other is for the Rear
posted on 17/1/11 at 06:47 PM Reply With Quote
No press required.
tomprescott
posted on 17/1/11 at 07:31 PM Reply With Quote
Can usually get away with a drift and a big hammer rather than a press - that said, sometimes its hard to find a hammer big enough.....
A bird in the hand....
