Author: Subject: Escort mk2 loom/sierra switchgear
Hornet
posted on 16/7/04 at 01:02 PM Reply With Quote
Hi Gents
I am attempting to wire up a xflow with an Escort mk2 loom and sierra column switchgear.
Does anyone have any advice... drawings etc.
For example, can the sierra switchgear handle the escort loom current or do i need to install relays?
Thanks in advance.
John
Bob da builder
posted on 16/7/04 at 03:32 PM Reply With Quote
hey up mate,
that is the same combo that im running but i took the easy way out and got a premire wireing loom, sent them my serria plugs and they fitted them onto the loom, excerlant service. but if you want to make you own then its worth a call, alan there realy knows his stuff and i cant speak highly enough of him, if you need bits then he will have them at good prices.
good luck
bob
paulf
posted on 16/7/04 at 08:57 PM Reply With Quote
I used the switch gear from an early Sierra, as these work without relays.I did add a relay to turn on the light circuit but didnt bother having seperate ones for high and low beam.I have only been on the road for a couple of weeks but no problems so far.
I think that the later switch gear requires relays as it switches to neutral instead of live.
Paul.
Originally posted by Hornet
Hi Gents
Thanks in advance.
John
MK7
posted on 19/7/04 at 10:03 PM Reply With Quote
I heard from MK that they reccommend fitting relays for all lights as the Sierra switch gear will only handle the current for so long.
I bought the MK wiring loom that was supplied with 2 relays, I ended up adding another 4 for the lights (main, dip side and fog)
I have a set of wiring diagrams that I made for myself, I think they're up to date (afteer several revisions).
If anyone wants a set then drop me a u2u with your email address and I'll send what I've got (without any warranty...)
Russell
Hornet
posted on 20/7/04 at 09:25 AM Reply With Quote
u2 sent dude
cheers
