Author: Subject: coilpack connections
dave r
posted on 18/3/12 at 05:03 PM Reply With Quote
what coilpack is this plug made for ?, as it dont fit mine..... and if i get the correct pack to suit the plug, will my ht leads still fit ?
[img] Description
[/img]
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
lotusmadandy
posted on 18/3/12 at 05:21 PM Reply With Quote
Why not do it the other way and get the
correct plug to fit the pack.
dave r
posted on 18/3/12 at 05:23 PM Reply With Quote
its a premade omex loom.
supposedly made to fit the coilpack i have...
may be easier/quicker to swap coil packs than try to return a loom i have started to fit
loggyboy
posted on 18/3/12 at 05:48 PM Reply With Quote
If its a Omex loom thats intended to be used on standard Zetec then they should be replacing it as the Oval connector is standard zetec Dispac.
dave r
posted on 18/3/12 at 09:01 PM Reply With Quote
duratec.... will that make a difference?
paulf
posted on 18/3/12 at 09:06 PM Reply With Quote
Theres plenty of zetecs with that plug in the scrapyard so I would just chop it off and fit the correct plug with a bit of solder and heat shrink assuming everything else is correct.
If you get stuck for the plug im sure that I must have one here somewhere.
Paul
dave r
posted on 19/3/12 at 03:28 PM Reply With Quote
got one on its way..... a new one
apparently the plug is the new duratec one....
