New Topic New Reply
Author: Subject: idle screw rubber o rings
RobBrown
posted on 16/9/13 at 08:22 AM Reply With Quote
BTW - Not sure this is the right section
Does anyone know where I can purchase replacement rubber O rings, that are on the ends of the idle mixture screw (R1 Carbs)?
I've seen sites in the US selling the complete Idle screw assembly for c.£15 per carb + shipping + duty. Also seen the carb refurb kit on ebay, again c. £15 including P&P per Carb.
All I need is the little rubber O rings (x4)
Rob
mcerd1
posted on 16/9/13 at 09:52 AM Reply With Quote
if they are just o-rings, then measure them up and search for ones that size on google etc...
just make sure they are the fuel safe type !
RobBrown
posted on 16/9/13 at 02:13 PM Reply With Quote
Managed to get 10 for £1.90 plus P&P form ebay. Bargain
search for "3mm O Ring", or seller called "sealforce53" if you want the same
mcerd1
posted on 16/9/13 at 02:33 PM Reply With Quote
too late for you now, but this lot have a good range and a little guide on picking the right material
http://simplybearings.co.uk/shop/Seals-O+Ring+Seals/c19_4501/index.html?gclid=CO7_7sGP0LkCFQbJtAodkhQAEw
RobBrown
posted on 16/9/13 at 04:00 PM Reply With Quote
Thanks. same items as from eBay, but more expensive.
rick1962uk
posted on 16/9/13 at 08:04 PM Reply With Quote
For motorcycle carb spares these are the best most shops use them give him a call always ready to help http://www.nrp-carbs.co.uk/
New Topic New Reply
