Author: Subject: R1 air corrector bore size
RobBrown
posted on 17/9/13 at 10:11 PM Reply With Quote
I've drilled mine out (previously soldered closed by someone else), which has removed the brass insert so I need to know what size to re-drill a new brass insert to, to bring them roughly back to stock.
Rob
BaileyPerformance
posted on 18/9/13 at 09:30 AM Reply With Quote
I did a 318 BMW recently with R1 carbs, we used 2.0mm mains and 0.3mm air correctors, fuelling was very close.
RobBrown
posted on 18/9/13 at 03:11 PM Reply With Quote
Does that mean you soldered and re-drilled them to 0.3?
As far as I can tell the air corrector (the one that's usually blocked) is a factory insert and isn't available on the standard parts list for these carbs (5JJ Year 2000 R1). It doesn't show up on any diagram schematic.
RobBrown
posted on 18/9/13 at 03:14 PM Reply With Quote
BTW its the one that looks like a blob (Marked A) on this picture that I have redrilled out and need to replace
Does anyone have a picture where they haven't blocked it
[Edited on 18/9/13 by RobBrown]
jacko
posted on 18/9/13 at 05:36 PM Reply With Quote
I am sure when boggs blocked my air correction holes they used 2.5 alloy rod that had to be knocked in to the brass hole
so at a guess the hole in the brass would be 2mm
This is on zx9r carbs so yours may be different
Jacko
BaileyPerformance
posted on 18/9/13 at 05:51 PM Reply With Quote
yes, we soldered up the factory inserts and drilled
RobBrown
posted on 18/9/13 at 08:01 PM Reply With Quote
Jacko
Thanks - The insert size is 3.5mm, so 2mm would make sense. Although I'm not convinced from what I have pulled out, the top of the insert is the same diameter as the bottom of it
As BaileyPerformance suggests I may start off small (0.5mm) and get bigger.
From my other post this will either be the thing that was wrong in the first place or just another red herring.
BaileyPerformance
posted on 18/9/13 at 08:39 PM Reply With Quote
Jacko
The standard air corrector is a stepped insert, outer edge is about 3.5mm, first part of the internal bore is about 2.0mm, the actual jet size is very small, less than 0.5mm as standard.
When the jets are blocked it only the first part if the jet that is filled.
You need around a 2.0mm main, drop the needles to lowest point, start with 0.3mm air corrector, If rich at top end drill the air corrector bigger.
When bike carbs are fitted to larger car engines the main jet does play a part in the idle fuelling as well as the idle system, so a way too small main will hamper starting.
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 19/9/13 at 10:16 AM Reply With Quote
Air correctors...
My R1 s, on a DanST manifold are fitted with Weber 180 main jets (1.8mm) After a couple of dyno runs we blocked the a/c jets with plastic padding stuff and before it set the operative pushed a very fine piece of wire through then when set drilled them to 0.5mm then after a couple more runs he re drilled them to 0.75mm and the AFR was almost perfect. This is on a Standard 2 ltr Black Top.
BaileyPerformance
posted on 19/9/13 at 10:27 AM Reply With Quote
More evidence of NOT to block air correctors, we have seen several cars with correctors blocked, start small and work way up is best. Don't forget that light throttle cruse is very important, check light throttle afr every time you make a change. The BMW we did idled at 14, cruse at 14.5, full throttle 12.8. As close as you will get with any carb.
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
posted on 19/9/13 at 10:32 AM Reply With Quote
I would point out that my engine is in a single seater hill climb car and is flat out from the lights going green.....
[Edited on 19/9/13 by redturner]
RobBrown
posted on 19/9/13 at 01:42 PM Reply With Quote
When you say lowest point is that the clip in the top position (leanest), so that the needle sits low.
Thanks - shame you are not round the corner.
BaileyPerformance
posted on 19/9/13 at 10:30 PM Reply With Quote
Yep, the needle position should only effect the light/medium fuelling, with a 2.0mm main you most likely will need the needle at the leanest position, clip at the top.
Get the WOT fuelling right first, if rich drill out the air corrector until you get it 12.5-13afr.
Try and get 14afr cruse, if leaner move the needle up until the fuelling comes right.
Your not that far away, we have had customers travel from London, Scotland, Channel Islands!
