Author: Subject: Dashboard
albertz
posted on 30/10/04 at 06:39 PM Reply With Quote
Dashboard
I am about to ask a stupid question, which i am sure will result in a stupid answer
Anyway, here goes.........
I am at the beginning of making my dash, so far i have a water temp gauge, oil pressure gauge and a voltage gauge. Obviously i need a speedo and rev counter. The lights and indicators are controlled by the existing column stalks.
What other switches and gauges should i buy/get? and has anyone got a decent basic layout as a starting point?
Mark Allanson
posted on 30/10/04 at 06:42 PM Reply With Quote
In addition to the obvious, a cooling fan over ride switch.
Ben_Copeland
posted on 30/10/04 at 07:27 PM Reply With Quote
What make gauges has everyone bought?
Think i like the look of Racetech ones, cheapish too.
Ben
Locost Map on Google Maps
Enter Your Details Here
posted on 30/10/04 at 07:35 PM Reply With Quote
We used the original ones from the Honda 'blade....
Bob C
posted on 30/10/04 at 07:38 PM Reply With Quote
Not going soft on me are you Ben? I've got a 99.9% complete digital dashboard with your name on it here - still have credibility gap re 1.4ohm oil pressure transducer.
What do you want to do? I'd suggest replacing the transducer, it's either broke or it's an "idiot" guage that's actually a switch - drop me a line
Bob
C
Ben_Copeland
posted on 30/10/04 at 07:41 PM Reply With Quote
AH... See the man himself appears. Hadn't heard from ya for a while.
I'll just email you now
Ben
wilkingj
posted on 30/10/04 at 07:45 PM Reply With Quote
Ah.. I have the same Dilemma, Anyone tell me whats reasonably good looking and reasonably priced gauges, speedo & Rev Counter.
Also any to avoid, ie from a reliability point of view.
Geoffw
Best Regards
Geoff
http://www.v8viento.co.uk
Ben_Copeland
posted on 30/10/04 at 07:47 PM Reply With Quote
Bob, you have an email
Ben
PioneerX
posted on 3/11/04 at 10:52 AM Reply With Quote
Just something to think about (as I had totaly forgotten about it until recently). If you plant to use the column switches so as not to clutter the dash with switches (as I thought), remember the column has no way to switch the fog lights.
BTW: My Guages are Telemetrix (£300 with sender, Speed, Recs, Fuel & Temp)
indykid
posted on 3/11/04 at 11:38 AM Reply With Quote
this is my finished dash, (finished last night)
gauges are smiths telemetrix, from europa with all senders and speedo pick up kit for £325. (where did you get yours pioneer?) Rescued attachment dash.jpg
posted on 3/11/04 at 11:48 AM Reply With Quote
Now that looks nice Indy!
wicket
posted on 3/11/04 at 01:05 PM Reply With Quote
Here's another, ETB instruments and 'hidden until lit' warning lights Rescued attachment Dash.jpg
PioneerX
posted on 3/11/04 at 01:09 PM Reply With Quote
IndyKid,
Europa too, but I get a show discount because they didnt have them all in stock at the show and had to backorder them for me.
Nice looking dash mate. Is the ingition switch in the SVA exempt area?
indykid
posted on 3/11/04 at 10:34 PM Reply With Quote
they're good at that at europa. i ordered a rear view mirror, £10 ish and they sent me an spa side mirror (£30ish), so i chopped it in against my fuel cap, as the same day, i'd ordered the exact same mirrors from demon thieves got my rv mirror from svc after that.
my starter is on the original key. those switches are rear fog and fan override, just so you know.
the switches actually sit behind the wheel, partly for sva purposes but also because they're really easy to get to from the belted up seated position. seemed logical really, until of course someone tells me that you can't put stuff behind the wheel. (please don't, i can't stand any more sva bo***x. )
tom
ps, now you see them
[Edited on 3/11/04 by indykid] Rescued attachment indydash.jpg
indykid
posted on 3/11/04 at 10:35 PM Reply With Quote
and now you don't, well quite as much
albertz
posted on 4/11/04 at 07:52 AM Reply With Quote
Thats a nice looking dash. What are all the warning lights for?
I assume the greens are indicators and the blue is main beam, what about the others?
indykid
posted on 4/11/04 at 11:17 AM Reply With Quote
the two red ones are brake level/hand brake and the other is oil pressure. the yellow is rear fog
hth
tom
Mark Allanson
posted on 4/11/04 at 08:11 PM Reply With Quote
Cheap and cheerful version, it only cost about £25 all in. Including 19mm marine ply, hippy roll, vinyl ans fastenings Rescued attachment Dash2.jpg
wilkingj
posted on 4/11/04 at 09:23 PM Reply With Quote
Thanks chaps (and any chapesses) thats great, its given me lots to think about. Gauges are a major expense, and I got a 2.1 tuned Pinto with fast road/race cam, twin 40 delorttos, and 4 branch exhaust for less than £325!!. However, its the wheels, seats, gauges and Dash that dominate the visual aspect of the vehicle.
Thanks to all.
Best Regards
Geoff
lenny
posted on 5/11/04 at 07:29 AM Reply With Quote
indy wot make dash is that ,just started the string side of my build and have not got round to think a dash yet Lenny
indykid
posted on 6/11/04 at 02:27 AM Reply With Quote
it's home made is that!
it's about the fifth blank we've made (me and pa) and is a single piece of 6mm mdf with two more layers laminated to the bottom to give an sva friendly radius rounded over with a router. the vinyl used is not from a kit car show, tried that last go and was not flexible enough but is from a local upholsterers, flexible enough to get round all but the top of the column cut out (neede nicking). aerosol contact adhesive and super glue secure it and give the above effect.
giva it a go, you'll be surprised what you can achieve!
tom
[Edited on 6/11/04 by indykid]
Northy
posted on 6/11/04 at 04:10 PM Reply With Quote
This is my attempt! Bit of a funny angle, but you get the jist! Rescued attachment Interior.jpg
Graham
