Author: Subject: fuel sender hole
macspeedy
posted on 7/11/04 at 03:27 PM Reply With Quote
fuel sender hole
wanting to know what size people have drilled the hole in there tanks for the fuel sender not wanting to take mine apart again, its for a friend.
JohnN
posted on 7/11/04 at 04:31 PM Reply With Quote
Surely depends upon the type of sender..........
My telemetrix sender stated 43-44mm dia., though I ended up wiggling it in through a slightly smaller hole, with no danger of anything shorting out.
posted on 7/11/04 at 07:58 PM Reply With Quote
Try using the sender unit gasket as a template, worked O.K for mine, hope this helps. Rusty
mangogrooveworkshop
posted on 10/11/04 at 11:54 AM Reply With Quote
Fuel Level Gauge (Arm type sender)
Fuel sender (Arm type sender)
Fuel Level Gauge (Dip type sender)
Fuel sender (Dip type sender) from
Whats the differance ?
Cheapest one for R1 gauge/light
[Edited on 10-11-04 by mangogrooveworkshop]
macspeedy
posted on 10/11/04 at 12:53 PM Reply With Quote
this is what you are looking for it is the arm type sender
http://www.rjays.com/Gauges/autometer_images/3262_large.jpg
