Author: Subject: Additional fan switch wiring
steve8274
posted on 25/4/14 at 05:17 PM Reply With Quote
Hello all
I am considering putting a switch in my car for the fan. At the moment, it operates via a fan switch in thermostat housing.
Is there a way to have the fan come on with thermostat switch and switch in car?
What type of switch would I need and could someone say or draw how to wire it?
Thanks in advance
omega 24 v6
posted on 25/4/14 at 05:26 PM Reply With Quote
Just connect them ( the switches) in Parallel. this will work if its direct control from the fan switch OR from a fan relay. If its direct them make sure you use a switch capable of taking the current required.
steve8274
posted on 25/4/14 at 08:29 PM Reply With Quote
Thanks for the reply.
However what you said means nothing to me😃
I have a very basic understanding of wiring at best. Have you a diagram or could you expand?
How would I know how much current my fan takes for the switch?
Thanks again
HowardB
posted on 25/4/14 at 08:32 PM Reply With Quote
like this,..
[img] Description
[/img]
Howard
posted on 25/4/14 at 09:10 PM Reply With Quote
All you will achieve is make the fan operation less reliable, just choose the correct fan switch and supply it from a permanent on supply.
omega 24 v6
posted on 25/4/14 at 10:49 PM Reply With Quote
What BT has said is quite true. But it does help ( the extra switch that is) in an emergency if the stat switch happens to fail. Some of the cheaper ones are very poor and fail.
snowy2
posted on 26/4/14 at 06:17 AM Reply With Quote
This exact question has been covered with a comprehensive wiring diagrams here......Wiring article
Hope it is of help....its one of two articles on the link..the second one is the one you want.
sometimes you are the pigeon, most of the time the statue.
snowy2
posted on 26/4/14 at 06:40 AM Reply With Quote
Originally posted by HowardB
like this,..
[img] Description
[/img]
if your using a relay you don't need a 30A switch. a micro switch will activate a relay safely. if you need a 30A switch you dont need a 30A relay there is no point.
do you know i really should read the post more carefully.....you say that on your diagram....ooops Sorry. Dave.
[Edited on 26/4/14 by snowy2]
snowy2
posted on 26/4/14 at 06:47 AM Reply With Quote
not true....many production cars use relays to switch the fan, and adding a manual switch in parallel to the thermostatic switch will have zero effect on it's operation. the manual switch just does the same job the thermostatic switch does........turns on the relay.
In fact using a relay actually makes the thermostatic switch more reliable over the long term, how its switched on will not affect any component in the given circuit.
omega 24 v6
posted on 26/4/14 at 09:45 AM Reply With Quote
I think the point being made is if you forget to turn the manual switch off when you are on the open road then it is counter productive to air flow through the radiator.
steve8274
posted on 26/4/14 at 09:52 AM Reply With Quote
Thanks for all the replies. Will give it a go this weekend. If I wire it with a warning light then hopefully I shouldn't leave it on
snowy2
posted on 26/4/14 at 07:19 PM Reply With Quote
My circuit above also illuminates a warning lamp on the dash, either with the manual switch or when the thermostatic switch operates. comforting when in heavy traffic.
adithorp
posted on 26/4/14 at 07:37 PM Reply With Quote
I did that using an LED. Unfortunately the wind blowing the fan around caused the motor to act as a dynamo and the LED flashed above 30mph. I had to put a diode in the line to prevent it back feeding.
http://jpsc.org.uk/forum/
snowy2
posted on 28/4/14 at 05:39 PM Reply With Quote
because my circuit is with a relay the same problem wont occur (the relay isolates the cct.)
