Author: Subject: Which battery lead?
posted on 19/11/04 at 03:16 PM Reply With Quote
Which battery lead?
here's another question for you all...
I have a battery isolation switch that I intend to fit to my car (not the type with a red key, as used in motorsport - this is a rotary one that's going on the firewall behind the dash.)
Physically the easiest lead to break into is the negative (chassis) one. Electrically it makes no difference which lead I disconnect, but is there any convention or hidden peril in breaking the negative lead instead of the positive one?
cheers,
posted on 21/11/04 at 10:51 PM Reply With Quote
Would connecting to anything other than the positive side of the circuit have any effect on the alternator diodes. I assumed the reason for this was due to the FIA Regulations and they are there for a reason...
Course - I stand corrected...
Mark Allanson
posted on 21/11/04 at 11:03 PM Reply With Quote
Put it on the earth, and put a 5A fuse across the terminals, all systems will still work unless the starter is applied!
posted on 22/11/04 at 08:31 AM Reply With Quote
Knowing me, I'll see the imobiliser light and try to start it!
My car's got very basic electrics - the only thing running when the car's stopped is the imobiliser, and I don't care if that's cut off when the switch is operated...
rgds,
