Author: Subject: duratec water flow
RickRick
posted on 12/11/14 at 08:36 AM Reply With Quote
duratec water flow
Hi
Could anyone tell me which way water flows around the duratec 2.0 engine
Paul Turner
posted on 12/11/14 at 08:58 AM Reply With Quote
Just like it does in every engine ever made.
The water heats up and exits via the head to the top hose of the radiator. The water cools in the radiators and exits via the bottom hose and enters the engine again normally via the water pump.
Simples.
RickRick
posted on 12/11/14 at 11:11 AM Reply With Quote
ok thanks that's what i guessed at, but we found a restrictor in the inlet to the pump on the sports 2000 car we run, and i think restrictors normaly would be on the outlet from the head rather than inlet to the pump
davidimurray
posted on 12/11/14 at 11:13 AM Reply With Quote
Restrictor or thermostat?
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
RickRick
posted on 12/11/14 at 12:37 PM Reply With Quote
def a restrictor penny washer welded into 10mm of pipe hole about the size of a 5p just stuffed into a rubber hose onto the pump inlet
