Author: Subject: sierra ignition
shaywez
posted on 28/11/04 at 12:15 PM Reply With Quote
sierra ignition
Hi all, i have a question about the connection to a sierra ignition as follws:
On my Luego loom i have the following according to the instructions
Supply terminal HD brown,2 x brown(perm live)
Ignition live terminal White's (switched live)
Starter terminal White/Grey (momentarily live)
The question being which one is which, ie permanent, switched and momentarily live. pins are numbered 30,15,50, also have another unmarked which is yellow (i think this is a radio connection) and one marked 'P' with nothing going to it.
Again i think the blk/bl is the starter connection, as for the rest all help would be very much appreciated. I hope i have managed to explain this ok
shortie
posted on 28/11/04 at 02:55 PM Reply With Quote
I'll have a look tonight for you if no-one else posts a reply, I am at work at the moment.
Rich.
shaywez
posted on 28/11/04 at 02:56 PM Reply With Quote
Thanks, much appreciated
bob
posted on 28/11/04 at 03:01 PM Reply With Quote
I'm sure your right re yellow,it comes up as auxilery in my pile of rubbish which act as my files.
I am now looking for the rest of my bits but i'm sure black/blue is as you say ign feed.
bob
posted on 28/11/04 at 03:08 PM Reply With Quote
OK i've got a different loom probably but mine is like this...red = supply and black ign live,black/blue is to starter solenoid and yellow wire in ford ign switch is as we said radio or unfused accessories.
I'll try and find the pin numbers info in the next hour or so,if its like relay numbers 30 could live feed in but i'll look.
posted on 28/11/04 at 04:29 PM Reply With Quote
Black blue is momentary live and only carries current when the key is in the start position to throw the solenoid in. The black yellow is the switched live and the red is permanent live. These are all you need unless you are fitting auxilliaries. Numbers are bk/y-15, bk/b-50, rd-30.
[Edited on 28/11/04 by Peteff]
bob
posted on 28/11/04 at 05:20 PM Reply With Quote
cheers pete I can throw my pile of papers back under the bench in the garage now,i might just sort them out and re-write them one day.
shaywez
posted on 28/11/04 at 05:24 PM Reply With Quote
Thanks for the help, i can now finish this bit off, cheers
lenny
posted on 29/11/04 at 09:19 AM Reply With Quote
can someone post all the pin numbers ,I HATE STRING, got all blade side of things but not the sierra switch side OH HUM Lenny
posted on 30/11/04 at 03:14 PM Reply With Quote
U2U Lenny
send me an email and I'll attach you the sierra diagram. Is it pre 87 or later you want.
lenny
posted on 1/12/04 at 05:03 PM Reply With Quote
thank you u2u on the way Lenny
BMF
posted on 2/12/04 at 01:33 PM Reply With Quote
couldn't send me a copy could you?
Cheers Ben
posted on 2/12/04 at 02:10 PM Reply With Quote
where to?
BMF
posted on 2/12/04 at 03:09 PM Reply With Quote
Good Point!
Sent Mail
