Author: Subject: Identify MX5 switch and ignition?
posted on 9/5/15 at 08:37 PM Reply With Quote
Bought these off ebay described as MX5 Mk1
http://www.ebay.co.uk/itm/Mazda-MX5-MK1-Steering-Column-Switches-inc-ignition-key-/151663715738?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2047675.l25 57&nma=true&si=U9rvaaobukTYWABXoMp2N9UXqjw%253D&orig_cvip=true&rt=nc
Did the MK1 have a sensor like this on it?
Steering lock diameter is miles too big for my 1990 column and the lock slot doesnt go anywhere near the pawl..
Anyone identify what model they are off??
posted on 9/5/15 at 08:39 PM Reply With Quote
Is the blue fitting in the top picture for an airbag? Did Mk1's have airbags??
big_wasa
posted on 9/5/15 at 08:47 PM Reply With Quote
I've got one of each and that looks like my mk2. You will also notice the switch gear is sloppy on the column. Hence why I am getting that mk1 switch gear next week if I can.
Yes blue plug is for the air bag clock spring.
posted on 9/5/15 at 09:05 PM Reply With Quote
Looks like Ive made a great error.. searching on goggle this may indeed be a mk1 WITH air bag, totally different to MK1 WITHOUT airbag....
Mk2 has the lights and wipers the either way round??
DOH, requested return so we will see what he says..
Thought Id bagged a bargain...
[Edited on 9/5/15 by coozer]
big_wasa
posted on 9/5/15 at 09:23 PM Reply With Quote
Give me a shout if he won't take it back I have a column it will fit.
I was told both mine where mk1 I assumed one was a mk2 because they are different.
I also have loads to learn on the mx5 differences.
posted on 9/5/15 at 09:53 PM Reply With Quote
Oooo aye, me as well... obviously!
Does the column you have that they will fit, fit a mk1 rack?
prawnabie
posted on 9/5/15 at 10:14 PM Reply With Quote
Same stalks as my mk1, although the box on the back is in the dash loom on mine.
posted on 9/5/15 at 10:32 PM Reply With Quote
Hmm, after googling I find they it should look like this???
big_wasa
posted on 10/5/15 at 07:11 AM Reply With Quote
I've got two columns, I was told both are from a mk1 but they are different from each other so I assumed I had a mk1 and a mk2 looks like I assumed wrong.
So I have two columns. Both have similar mounts both have the same splines each end one column is a touch longer. The switch gear I've got is the same as yours. The switch gear on the mk1 I looked at yesterday is also the same as what we both have.
Next week I plan to have all the mx5 donor bits I need and will get rid of what's left. I am now seeing the merit in grabbing all the parts from one donor.
garyt
posted on 10/5/15 at 07:51 AM Reply With Quote
watch out for the wiring block connector and double check switchgear wires to harness wires as even with mk2.5 03 stalks and mk2.5 03 harness they didn't match up ###**** ??? spent hours trying to figure out why my lights wouldn't work simply unclipped the connecting pins in one block and swapped around till it made sense and worked.
now fighting with indicators
there appears to be a lot of differences throughout and yes I now wish I could have got a single donor too.. cest la vie
but then where's the fun in making it easy ...........
going out to do a bit more wiring today, not my favourite job I must admit, but each time I get a bit done its a bit closer to being done
Gary
remember we are not mad just creatively insane !!!!!
big_wasa
posted on 10/5/15 at 03:00 PM Reply With Quote
How many wires just for the indicators............
garyt
posted on 12/5/15 at 05:27 PM Reply With Quote
Hi sorry for the delay I getting back to you, on the switchgear I have its green / yellow - turn fuse, green / white - right indicator, green / black - left indicator
and on the harness its, pink/white - turn fuse, black/red - right indicator, green / yellow - left indicator.
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! all are supposedly '03 mk 2.5
no wonder I had a sore head
Gary
big_wasa
posted on 16/5/15 at 12:54 PM Reply With Quote
Thanks Gary, much more complicated than ford
I've just pulled some more switch gear from a late mk1 and it's the same chunkier column stuff as yours Steve.
big_wasa
posted on 16/5/15 at 01:20 PM Reply With Quote
Did you manage to send them back Steve ?
posted on 16/5/15 at 02:18 PM Reply With Quote
Yes mate, returned and got a refund..
Maybe I should have kept them and sourced the correct column!
big_wasa
posted on 16/5/15 at 02:55 PM Reply With Quote
I've managed to make a complete set but its using the late mk1 chunkier column and switch gear.
