Author: Subject: Pumping Kerosene.
Staple balls
posted on 19/6/15 at 09:06 AM Reply With Quote
Pumping Kerosene.
So, due to landlord related issues, I need a shift a few (maybe 150) litres of kerosene.
I know the pikeys use these but I suspect there's a slight risk of loss of fingers.
This looks a bit more promising, but again with the no flammables.
Any ideas chaps?
mcerd1
posted on 19/6/15 at 09:13 AM Reply With Quote
what about an electric lift pump off the fuel tank of any old diesel car/van/lorry....
posted on 19/6/15 at 09:22 AM Reply With Quote
Kerosene like diesel vapour is normally below the danger point electric pump should be no problem.
Im my experirncr electric drill pumps are normally pretty cr**
big_wasa
posted on 19/6/15 at 10:27 AM Reply With Quote
150L is around £50 worth, not a lot of point spending £30 to get it out. Depending on the age of the tank there will be sediment and water in there any way.
If the tank is of the floor just take the pipe of and fill some 25L tubs
blakep82
posted on 19/6/15 at 11:11 AM Reply With Quote
Cheap electric fuel pump off eBay? Can be had for under a tenner
http://www.ebay.co.uk/itm/12v-Universal-Electric-Fuel-Pump-Suitable-for-Diesel-Petrol-Engines-12-Volt-/221746787792?pt=LH_DefaultDomain_3&hash=ite m33a12375d0
________________________
Staple balls
posted on 19/6/15 at 11:32 AM Reply With Quote
The tank is pretty new, and frankly, I'd rather take it and dispose of it at the tip than leaving this delightful gentleman anything of any value.
Brian R
posted on 19/6/15 at 11:59 AM Reply With Quote
Something like this would do the job.
http://www.ebay.co.uk/itm/12V-Water-Submersible-Pump-Refueling-Transfer-Oil-Diesel-Fuel-And-2M-Outlet-Hose-/351429901731?pt=LH_DefaultDomain_3&has h=item51d2dabda3
RickRick
posted on 19/6/15 at 02:28 PM Reply With Quote
we use a fuel injection pump same as fitted to my bec to pump petrol in and out of the race car, give a decent flow rate just push rubber hoses on each end seems to be fairly good at self priming too.
not 100% sure how it would work with kerosene other option is a tank or lift pump from a diesel in the scrappers
Staple balls
posted on 19/6/15 at 02:41 PM Reply With Quote
Thinking about it, I do happen to have a scrap diesel felica on the drive, that might work.
ste
posted on 19/6/15 at 07:09 PM Reply With Quote
Just tip a load of sawdust in there then
Staple balls
posted on 19/6/15 at 07:11 PM Reply With Quote
bi22le
posted on 19/6/15 at 10:11 PM Reply With Quote
That is evil, I like it!
Please read my ring story:
