Author: Subject: FS: Xflow Mounting Brkts
Dick Axtell
posted on 23/7/15 at 08:05 PM Reply With Quote
Here on the 'Bay - ETDWM.
http://www.ebay.co.uk/itm/181811701509?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
You never know, someone might still want to fit the older engine!
jonrotheray
posted on 24/7/15 at 08:05 PM Reply With Quote
Can you measure the height of these? When fitted, what's the vertical distance from the bottom plate to the centre of the engine mounting plate?
I want to know if these will let my engine sit a little lower!
Dick Axtell
posted on 25/7/15 at 07:14 AM Reply With Quote
Will make measurements today, and let you know. Have 2nd pair brackets which allowed slightly lower position for xflow. Dimensions later.
E-Bay Brkts: Distance from bottom plate to centre of engine plate = 12.5cms.
Add another 4cms for the rubber donut thingy, and there will be your mounting height for the block attachment point.
Checked the 2nd pair brkts. The height distance is very similar to the E-Bay brkts.
[Edited on 25/7/15 by Dick Axtell]
