Author: Subject: 1800 Zetec Turbo Megasquirt settings
James300481
posted on 2/11/15 at 07:14 PM Reply With Quote
I'm currently trying to map my 1800 Zetec turbo, it doesn't seem to be running that well, rich if anything.
It has 250cc injectors required fuel is set at 10, have included screenshots of the spark adv, afr and ve tables.
Any comments, would be greatfully received
James
madteg
posted on 2/11/15 at 07:58 PM Reply With Quote
Hope this works, here is my maps 2l zetec turbo
[email=boothmuscle87@googlemail.com]file:///C:/Users/kevin%20booth/Pictures/2014-11-18%20camera%20kit%20car%20show/My%20zetec%20turbo%20map.png[/email ]
madteg
posted on 2/11/15 at 08:00 PM Reply With Quote
[img]file:///C:/Users/kevin%20booth/Pictures/2014-11-18%20camera%20kit%20car%20show/My%20zetec%20turbo%20map.png[/img]
James300481
posted on 2/11/15 at 08:04 PM Reply With Quote
Can't see them unfortunately
SteveRST
posted on 3/11/15 at 11:44 AM Reply With Quote
You can't share a file that is located on your PC. You must upload it to the web. Use dropbox or photobucket or something similiar - they're free.
SteveRST
posted on 4/11/15 at 11:06 AM Reply With Quote
My maps - 2.0 zetec turbo, standard internals with 3mm decomp plate, 470cc injectors, cosworth T3 turbo, electronic boost control, max 180kpa / 0.8 bar / 11.5 psi.
The car runs well, and has been running for 2 years now, but BEWARE - it's never been professional tuned or on a rolling road. I have just used auto-tune and refined the maps many times. I'm still learning! (But enjoying doing so )
In the MegaSquirt setup - General settings - do you have "Incorporate AFR target: " set to 'Include AFR target'? I think that can make the VE table look quite different. Note, if you change the setting I believe that you have to re-tune or manually re-calculate your VE table values.
I'd think your 250cc injectors are going to be at their limit. Maybe a bit small?
Let's have some pics of your zetec turbo setup.
Oddified
posted on 4/11/15 at 06:12 PM Reply With Quote
Depending on what power your looking to get, the 250cc injectors will be maxed out quite easily. I'd be inclined to get larger ones fitted before spending to much time mapping or you'll end up doing most of it again.
Ian
