MB
posted on 13/10/02 at 09:33 PM |
x-flow misfire
My part built currently has a Mk2 Escort x-flow. Have given it new plugs, leads, consensor, points etc, but it misfires badly when you increase
engine speed.
It starts without problem, and idles okay and fires on all plugs - it just misfires above idle speed.
Engine used to work okay, when I last tried it about a year ago...
posted on 14/10/02 at 07:49 AM |
Cracked, dirty or damp distributor cap?
Stuck advance weights in the distributor?
Just a thought or two...
D Beddows
posted on 14/10/02 at 12:26 PM |
What carb has it got on? does it misfire at all rpm above idle or is just at one particular spot in the rev range? I've had huge problems with 2nd
hand twin choke webbers recently so if your using one of them I might have a few ideas
Pure5ty1e
posted on 15/10/02 at 03:33 PM |
Sounds like a clogged/wrong primary jet or something, idle jet lets it run fine, but when you move of the idle it runs bad. Check it and clean it!!
jollygreengiant
posted on 18/10/02 at 09:32 PM |
xflow misfire
It might sound pretty stupid but have you checked the points and is it a fomoco distributor, problem that I had with them was that the thin plastic
strap bewtween the points rivet and the operating heel some times goes week or has no reinforcing rib down its back. The result is that it started ok
but as it got hot or the revs increased then the heel colapsed leading to a teribble misfire. The cure was to change the distributor to a lucas unit
from a pre-xflow.
Rick
posted on 19/10/02 at 07:32 AM |
Change the dizzy to an old Fiesta electronic ignition one.
The whole thing will run a lot better.
Got my one with coil for £15 runs lovley now.
Rick
