<<  1    2  >>
New Topic New Reply
Author: Subject: What would you have done differently?
Mansfield
posted on 28/12/04 at 07:53 PM Reply With Quote
Hi, my name is David and this is my first posting.
I am in the 'planning' stages of my first build. I have the Ron Champion 'Bible' and one thing is obvious - as I am not going to be using a Ford Escort as a donor vehicle (because I dont think I will find one) I will be unable to use the book to the letter.
A million pitfalls spring to mind, but please tell me, if you would be so kind, what would you have done differently for your first build?
My engineering and design skills are above average but my wallet opening skills are almost non-existent. I do, however, recognise that I will NOT be building a car for £250 and that money spend in the right areas will be an investment.
Thanks.
Rob Lane
posted on 28/12/04 at 08:06 PM Reply With Quote
You don't neccessarily need the Escort to build a book car.
Engines, gearboxes, back axles, uprights, brakes etc are all available from ebay or other sources. See some of the for sale on here and keep a lookout for items appearing.
Bodywork is available from any of the suppliers on this site.
Jon Ison
posted on 28/12/04 at 08:07 PM Reply With Quote
only thing i would have changed is id'e have put a bike engine in 1st instead of the pinto, could have had a smaller trans tunnel if ide have known what i was gonna do,
if you can find a Cortina, make a great donor.
where you at ? if its Mansfield i'm just down road.
locodude
posted on 28/12/04 at 08:28 PM Reply With Quote
Rebuilt the x-flow and not put a bag of sh1t bike engine in, I'd still have it now
Mansfield
posted on 28/12/04 at 08:41 PM Reply With Quote
I am indeed in Mansfield.
I think I favour the 'one donor' route which I am assuming will be some form of Sierra. I would love to build the chassis myself but I have read on a builders website (forget which one) that he wished he had bought a frame ready built. God Ron says this is 50% of the build. I am a biker at heart but cannot open my wallet far enough to but a decent engine AND all the bits I would need from at least one donor car.
scutter
posted on 28/12/04 at 08:42 PM Reply With Quote
tempted to build another one Chris (still be SVA'd before mine)
ATB Dan.
Jon Ison
posted on 28/12/04 at 08:45 PM Reply With Quote
if you aint building the chassis buy a sierra and an MK indy kit, if your building your chassis buy a cortina and nick the engine out ya bike.
weather permitting i'm hoping to nip over too MK one day this week, providing there open that is, come along and have a peek.
[Edited on 28/12/04 by Jon Ison]
Mansfield
posted on 28/12/04 at 09:22 PM Reply With Quote
I am also very close to Robin Hood Engineering, is that a dirty phrase on this forum?
Mark Allanson
posted on 28/12/04 at 09:25 PM Reply With Quote
Not dirty, just a common source of mirth
Mansfield
posted on 28/12/04 at 09:30 PM Reply With Quote
Is it the Lada of the kit/seven car world?
Mark Allanson
posted on 28/12/04 at 09:38 PM Reply With Quote
More of the comedy support act
mookaloid
posted on 28/12/04 at 09:49 PM Reply With Quote
You could argue that a R**** H**d looks like a seven, but under the skin they are nothing like.
The biggest problems are the chassis, the rear axle and suspension, the front suspension, the interior, the exterior, er and I think that there was some other stuff too but I cant remember it all...
Mark
Mansfield
posted on 28/12/04 at 09:58 PM Reply With Quote
Okay. the Hood is a No No. What are the pitfalls of a Sierra powered Ron Champion?
Mark Allanson
posted on 28/12/04 at 10:08 PM Reply With Quote
To be fair to RH, some of the stuff is useable, but with quite a lot of fettling. Some people have made quite good cars, but they are not straight forward, easy or conventional. They are made down to a price, I suppose you get what you pay for, £1000 is not a lot for a full kit
Simon
posted on 28/12/04 at 10:09 PM Reply With Quote
Where would you like to start?
Front perhaps? Steering rack to wide unless you build chassis wider. Four inches is good! Engine? You may be unfortunate enough to end up with a 1.8CVH. I was and threw it in a skip
Rear suspension will need to be replaced with either De Dion or IRS. See Craig1410's website re details of de Dion if you go that route. If IRS buy Tiger Avon book and bastardise the two chassis.
If you build chassis wider, you'll need to make your own or mod someone elses rear panel/scuttle/bonnet and nose.
If you go wider, you may also like to consider putting in a proper engine.
What would I do if I knew then what I know now?
Buy a Viento and be on the road two years ago!!!!!!!!
HTH
Simon
PS Welcome to the forum
Mansfield
posted on 28/12/04 at 10:12 PM Reply With Quote
I have read there are chassis plans FOC at 4" wider courtesy of mscmorely, is this a good bet?
And what would you call a proper engine?
krlthms
posted on 28/12/04 at 10:17 PM Reply With Quote
Mark
Driver?
Mark Allanson
posted on 28/12/04 at 10:29 PM Reply With Quote
I think the McSorely plans are essential, whichever one you choose. I disagree with the advise about using the Tiger rear end. A pile of tubes thrown in the general direction of you car and then welded where they fell would have a better design, the GTS DeDion has got to be the easiest, cheapest and most competent option to a live axle.
posted on 28/12/04 at 10:38 PM Reply With Quote
Here, save money by putting a Pinto engine in - then double it when when you've experienced a bike engined car - seems like a growing number of CEC owners are swapping to BEC if they're not BEC already!
Save up for a more worthwhile investment... go BEC!
paulf
posted on 28/12/04 at 10:56 PM Reply With Quote
I would have used round tube and sloped it downwards at the sides by you elbows as the original seven.
This is one thing iI did not do and have always regretted.
I put in a crossflow engine even though i have a blade engine ready to fit, but cant bring myself to rip it all out to fit a bike engine now its finished as to much work with exhaust, prop and dash to change.
I also would go for the GTS de dion if using a sierra donor.
Paul.
stephen_gusterson
posted on 28/12/04 at 11:46 PM Reply With Quote
keep it simple and stick to the book or the mcsorely plans as much as you can. or buy a kit, which will give you a huge start and make things easier and give a faster build.
All things I didnt do.....
If you actually look at the bits you really need from an escort, its precious little! So an escort is not essential. a mk4/5 cortina appears to be the best fit - but they are a tad rare
atb
steve
[Edited on 28/12/04 by stephen_gusterson]
posted on 29/12/04 at 11:54 AM Reply With Quote
Yes, the McSorley plans are much better than the books, they don't have a numerous errors for a start, and you also get a proper drawing for each chassis member to help with cutting.
The 2.0L Pinto is a good budget engine. It's a bit heavy and not overly powerfull in standard form, (but enough power to make a locost move pretty quickly). However, it's simple and easy to work on, it comes with the donor (if you buy a suitable Sierra) and there is still a huge range of tuning bits if you want more power later on.
OF the engines fitted to the Sierra, avoid the 1.8CVH and the later 8valve DOHC engine (very tall and more difficult to fit into locost). The 1.6 Pinto is hardly worth bothering with either, as there are so many 2.0 lumps avalable.
A more modern alternative is the Zetec which can be picked up pretty cheaply, and will bolt up to a Ford Type 9 gearbox with the appropriate mix of clutch components. It was never fitted to the Sierra though.
Volvorsport
posted on 29/12/04 at 12:38 PM Reply With Quote
well , after buying a chassis second hand , i would deffo build a +4 , it gives you more options - but then im wanting to build a complete composite chassis . Dont overlook some more mundane donors that have more powerful engines as std . If youre buying a kit , stick to it .
www.dbsmotorsport.co.uk
getting dirty under a bus
Mark Allanson
posted on 29/12/04 at 12:51 PM Reply With Quote
I agree with everything Mike has said, the 18CVH can be fitted without insummountable problems, but is very fragile if not properly serviced throughout its life, and you are limited to 90bhp.
The pinto will fit into a book chassis, but it is VERY tight, if you drop a socket, it never reaches the workshop floor! Rescued attachment TightPinto.jpg
James
posted on 29/12/04 at 01:50 PM Reply With Quote
I'd have done the following differently:
For fitting the Pinto I'd have added 1" height to the chassis/engine bay.
Used GTS' De Dion back end (as opposed to my own IRS system).
Mounted the engine lower.
plus numerous other things...
HTH,
James
[Edited on 29/12/04 by James]
<<  1    2  >>
New Topic New Reply
