Author: Subject: Duratec Timing Chain Kit
neilp1
posted on 6/9/16 at 05:24 PM Reply With Quote
Anyone used one of these kits for their rebuild?
FORD FIESTA ST150 2.0 16V 04-07 NEW TIMING CHAIN KIT + HEAD GASKET SET & BOLTS
If so are they any good??
davidimurray
posted on 6/9/16 at 07:33 PM Reply With Quote
I used one of them. only done 1000miles but no complaints so far.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
neilp1
posted on 7/9/16 at 02:54 PM Reply With Quote
Cheers for that, I'll order one.
Did you change the main bearings when you done your rebuild??
Hornet
posted on 7/9/16 at 06:39 PM Reply With Quote
Hi bud, I changed main and big end bearings all from burton power.
davidimurray
posted on 7/9/16 at 09:12 PM Reply With Quote
I left the mains alone on mine. I changed piston and rods only because I could get a full set from an unused crate engine cheaper than just a set of piston rings!
neilp1
posted on 16/9/16 at 08:03 PM Reply With Quote
Did you hone the bores yourself??
neilp1
posted on 16/9/16 at 08:04 PM Reply With Quote
What make of bearings did you buy as I've been looking at some king racing ones on ebay.
Hornet
posted on 16/9/16 at 08:29 PM Reply With Quote
King racing are good bearings, Mahle are used in Mercedes as explained by Burton so I bought them
