Author: Subject: Relocating battery to footwell
Banana
posted on 7/1/17 at 04:03 PM Reply With Quote
Has anyone else relocated the battery to the passenger footwell?
With an access hatch from the engine bay where it currently sits.
Benefits i see -
Tidier engine bay
Lower COG
Will be covered by foot rest/kickplate in foot well, so out of sight.
Any potential downsides I've missed?
[Edited on 7/1/17 by Banana]
posted on 7/1/17 at 04:37 PM Reply With Quote
yes, all of the above.
another item to the list is plan some way to connect a battery charger - I didn't get round to it so need to remove bonnet then connect positive lead to solenoid terminal; a pair of connectors inside the car would have been a more convenient option.
CosKev3
posted on 7/1/17 at 05:12 PM Reply With Quote
Leg room for passengers is a possible downside
posted on 7/1/17 at 07:06 PM Reply With Quote
Just make sure any acid is contained in the event of an accident. TVR put the battery in the passengers footwell on some models
gremlin1234
posted on 7/1/17 at 07:16 PM Reply With Quote
a more expensive solution maybe a lithium battery, (smaller and lighter) either in the engine bay or footwell.
40inches
posted on 7/1/17 at 07:22 PM Reply With Quote
A smallish car battery fits fine, and only takes up the space the pedals do, on the other side
posted on 7/1/17 at 08:49 PM Reply With Quote
Yes, i put mine there from the start..
What you see there is a red top 25 sitting on a piece of foam with the remains of a stainless deep fat frier holding it in place.
I ran the cables through the bulkhead with some plastic bulkhead fittings.
posted on 7/1/17 at 08:51 PM Reply With Quote
Forgot to add, I then bent a piece of ali to cover the whole lot and stuck it on with velcro.
Banana
posted on 7/1/17 at 09:13 PM Reply With Quote
Velcro and deep fat friers - gotta love kit cars.
Looks good though.
[Edited on 9/1/17 by Banana]
gremlin1234
posted on 7/1/17 at 09:34 PM Reply With Quote
as is the 100mm ball requirement for 'blunted edges' in this part of the passenger compartment. - ie clamps holding it down and its terminals should be blunt, or covered. (as well as the terminals being covered from an electrical pint of view.)
Banana
posted on 8/1/17 at 12:54 AM Reply With Quote
It will be walled off, so to speak.
Or a footrest in front.
40inches
posted on 8/1/17 at 11:12 AM Reply With Quote
Ally panel sealed with Sikaflex. A 6ft 4inch friend found it made a nice footrest
907
posted on 8/1/17 at 12:28 PM Reply With Quote
I would want to be able to quickly disconnect the battery in the event of a mishap.
I believe this is the case at some tracks as well.
Paul G
FuryRebuild
posted on 8/1/17 at 03:34 PM Reply With Quote
Bentley learned this one in their first year returning to Le Mans. They had a battery failure and had located the battery right way down in the car for CoG benefits. It took a long time (relatively) to replace and they lost places. Now, the batteries are mounted higher up and further out so they can be reached more easily. For me if I were endurance racing, I'd have the battery connect to the car on a power connector, so it's a 20 second swap.
Paul G
www.furyrebuild.co.uk
Banana
posted on 8/1/17 at 07:12 PM Reply With Quote
Im going to fit an inline isolator/key, for both security and safety.
907
posted on 8/1/17 at 07:13 PM Reply With Quote
I have one of those "big red key" switches fitted.
I must confess, the main reason was for when leaving the car unattended at shows.
Those lovely little angels, watched by their parents, play with the switches and leave them on.
Paul G
myke pocock
posted on 8/1/17 at 08:31 PM Reply With Quote
I sense another winter mod coming on for me. Dont you just love this Forum for ideas.
Banana
posted on 9/1/17 at 06:34 PM Reply With Quote
Talking of those 'big red keys' - are they man enough to take the current to the starter motor?
I was thinking of leaving the starter wired direct to the battery and having everything else via the isolator key.
But ideally, id have everything go through the key. If its up to the job.
gremlin1234
posted on 9/1/17 at 07:56 PM Reply With Quote
usually they will be fine for the starter current
for instance
https://www.amazon.co.uk/d/k5c/Car-Battery-Isolator-Cut-Off-Switch-500A/B003DYQYXC
is 500A
Banana
posted on 9/1/17 at 08:12 PM Reply With Quote
Cheers Gremlin!
HowardB
posted on 9/1/17 at 08:20 PM Reply With Quote
Here's my take on the idea....
Footwell
Footwell
Hth
Howard
Banana
posted on 9/1/17 at 09:40 PM Reply With Quote
Exactly what i envisaged from the start
Think i might end up with more legroom than yours though..
bi22le
posted on 10/1/17 at 01:05 PM Reply With Quote
Mine is in the 'boot' to level the COG out even more so. I didn't do this but its quite neat.
Please read my ring story:
FuryRebuild
posted on 10/1/17 at 01:41 PM Reply With Quote
Is it inside our outside of the wheelbase? I'm thinking about polar moment of inertia.
907
posted on 10/1/17 at 01:57 PM Reply With Quote
My usual passenger in the car is the Missis.
She says that she is the ideal passenger as she now has a lower centre of gravity.
Paul G
