Author: Subject: Converting a megajolt from tps to map
Shooter63
posted on 17/1/17 at 10:04 PM Reply With Quote
Do any of you guys know how to convert a megajolt v4 from tps to map sensor, I've got the little sensor that fits on the board and just seems a solder on job, but is there anything else I need to Do?
Shooter
r1_pete
posted on 18/1/17 at 01:38 AM Reply With Quote
I did this a few years ago, there was a kit available, it included the vacuum sensor, and a couple of replacement components, best thing to do is contact Autosport Labs and see if the kit / instructions are still available,
mcerd1
posted on 18/1/17 at 09:06 AM Reply With Quote
one of the reasons they stopped selling MJ as a DIY kit is that the V4 design was updated to use surface mounted components which are harder to work with
but for a very short time the V4 was available as a DIY kit (before they decided too many people had issues building them) and the V4 assembly instructions are actually still on the wiki (but the link has been removed)
https://wiki.autosportlabs.com/MJLJ_V4_kit_assembly_guide
^^ that link will give you the details of the parts etc - but here is the guide on converting them from the horses mouth:
https://forum.autosportlabs.com/viewtopic.php?p=10986&sid=01d99e055e98b5f66106160c18c10f87
As I understand it you can't run TPS and MAP at the same time, you need to at least disable one of them - but the autosportlabs forum is the best place to get more advice on how to do it
But I'd ask do you really need to change it / is it worth the hassle ?
If you can get a stable vacuum reading, MAP sensing is generally considered to be superior as it more closely measures the actual load on the engine. However, TPS still works fine
[Edited on 18/1/2017 by mcerd1]
