Author: Subject: Everything works without key in ignition...
furryeggs
posted on 6/2/17 at 08:54 PM Reply With Quote
I've finally sorted out connecting up all of my wiring. At first everything was ok, some how i've managed to get all the lights,indicators and dash lights working as intended first time. The Ignition key is wired as tiger intended (i checked with tiger) all positions are ok and the engine cranks and stops when released. I accidently popped a fuse and since its been replaced everything works without the key being in the ignition, the lights, side dip and main beam, indicators, hazards, brake lights, everything, even dash lights.
It's almost like the i have a permanent connection to 12v... I haven't had muchtime since to investigate further but my first thought is my ingnition barrel is buggered.
Any ideas where i can start to look?
Ben_Copeland
posted on 7/2/17 at 10:16 AM Reply With Quote
Either wiring is wrong, ignition barrel is fried or the relay is stuck. Can't really think of anything else
Ben
Locost Map on Google Maps
Enter Your Details Here
r1_pete
posted on 7/2/17 at 11:04 AM Reply With Quote
Did everything work properly via the switch before you blew the fuse?
furryeggs
posted on 7/2/17 at 03:32 PM Reply With Quote
I'm pretty sure it all worked ok, Just been down to check, no key in = lights side dip and main + dash lights when on, horn and hazards + correct dash lights and dials illuminate with the lights on,. everything else stays off until ignition is switched on, then indicators, fuel pump etc all work.
I'll test the barrel later to check
r1_pete
posted on 7/2/17 at 04:46 PM Reply With Quote
That sounds correct to me, my cars are pretty much the same.
furryeggs
posted on 7/2/17 at 05:56 PM Reply With Quote
If thats the case then all is well I'll still have a double check mind.
r1_pete
posted on 7/2/17 at 06:51 PM Reply With Quote
Ive just been out in the L200 and thiught about your post when I came in:
Ign on, engine, indicators, radio, plus as below...
Ign off, all lights, horm, hazzards, brake lights....
If leave the lights on and open the door I get a buzzer.
The only ones I didnt check were the reverse lights....
Adamirish
posted on 7/2/17 at 07:31 PM Reply With Quote
Mine does the same too. I think it's a requirement to have at least the side lights working without the key.(parking lights)
I get sidelights, headlights, hazards(obviously) and horn without the key.
MK Indy 1700 Xflow
ReMan
posted on 7/2/17 at 07:34 PM Reply With Quote
Yes mine is wired like that
Sidelights and instrument lights and hazards and horn work, with ignition off
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
furryeggs
posted on 7/2/17 at 08:52 PM Reply With Quote
Good oh. Thought i'd check.
Ben_Copeland
posted on 8/2/17 at 06:34 AM Reply With Quote
Ok so it's all working as it should. So everything doesn't work with key not in then, as per original post? Just the lights, although indicators don't usually work unless ignition is on.
Ben
