Author: Subject: Ford EEC-V (SHAY) ECU pin numbers
package626
posted on 30/3/17 at 09:01 AM Reply With Quote
Hi
I have a Ford EEC-V (SHAY) ECU 60pin.
I am after a diagram etc.. that shows what pin number is what?
if anyone can help that will be great.
Thanks in advance
snowy2
posted on 30/3/17 at 10:28 AM Reply With Quote
they tend to be all the same pin arrangement on the 60 pin ECU's
check that yours matches......
the numbers with nothing written there is an unused pin.
also look at the fitting the zetec on standard ecu as a sticky on the fuel injection heading....the 60 pin is covered in the 104 pin stuff
The wiring for the 60 pin ECU's is listed here.
Pin Colour
Function
1
Red
Battery
2
3
White/blue
Vehicle speed sensor (VSS)
4
White/purple
Audio/cruise/trip
5
White/green
Immobiliser control module
6
White/red
Air con
7
White/purple
Cylinder head temp (CHT)
8
Green/black
Fuel pump relay
9
Purple/blue
Mass air flow (MAF)
10 Green/yellow
Air con (AC)
11
12 Black/white
Injector 1
13 Black/blue
Engine coolant blower motor relay 1
14 Black/orange
Injector 4
15 Black/yellow
Injector 2
16 Black/yellow
Earth
17 Orange/black
Data link connector
18 Blue/black
Data link connector
19 Grey/orange
Data link connector
20 Black
Earth
21 Black/yellow
Idle air control (IAC)
22 Black/blue
Evaporative emissions (EVAP)
23
24 White/purple
Camshaft position sensor (CMP)
25 White/purple
Intake air temp (IAT)
26 Yellow
Throttle position (TP)
27
28 White
Power steering pressure(PSP)
29
30 Brown/white
Camshaft position sensor (CMP)31 Black/white
Engine coolant blower motor relay 2 AC
32 Black/red
Starter motor relay
33 Black/yellow
Heated oxygen sensor (HO2S)1
34 Black/blue
Injector 3
35
36
37 Green/yellow
Engine control relay
38 Grey/orange
39 Black/orange
Immobiliser LED
40 Black/yellow
Earth
41 Blue
Alternator
42
43 White
Clutch pedal position (CPP)
44 White
45 Grey
Alternator
46 Brown
CPP, CHT, HO2S, IAT, TP
47 White
Throttle position sensor (TP)
48 White/red
Heated oxygen sensor (HO2S)2
49
50 White/blue
Mass air flow (MAF)
51 Black/blue
52 Black/green
Ignition aux circuits relay
53 Black/blue
Fuel pump relay
54 Black/yellow
AC compressor clutch relay
55 Brown/red
Crankshaft position (CKP)
56 White/red
57 Green/yellow
58 Black/red
Ignition coil
59 Black/green
Ignition coil
60 Black/yellow
Earth
sometimes you are the pigeon, most of the time the statue.
snowy2
posted on 30/3/17 at 10:36 AM Reply With Quote
I have fitted one of these to my car with the standard ECU i have been working on an article for our club magazine...
here is a link to my google drive where it is located... fitting the 60 pin ecu
or look here on this forum Locost
package626
posted on 30/3/17 at 11:38 AM Reply With Quote
Thats all great i appreciate your help.
seems you know what your taking about, i wonder if you can help me a bit more?
I want to strip the loom back to basic to run 1.3 Endura. can you tell me what wires i need to keep in order to make the car run but not have all the birds nest. I know you need the key and key reader or ya got no chance lol..
I have enclosed a video link and some pictures for attention.
https://www.youtube.com/watch?v=9uxvInxSDh4
package626
posted on 31/3/17 at 06:12 AM Reply With Quote
would someone please tell me what the best pin number is to earth the ECU?
I know u only need 1 earth and 1 live. from looking at the info above i would use 1 & 20 would thins be correct?
snowy2
posted on 1/4/17 at 09:02 PM Reply With Quote
The post to the article I wrote for my club mag gives you all you need. You do need the key to match the ecu.
snowy2
posted on 1/4/17 at 09:03 PM Reply With Quote
All of the ecu earth's need to be made and it's best for them not all to the same place.
package626
posted on 2/4/17 at 06:34 AM Reply With Quote
I have narrowed it down to what i dont need, In your write up it says u need about 11 connections.
could you possibly confirm what connections these are to compare to my list.
Also you only have 3 injectors listed, is that correct? and unless i have missed it, what pin number do i need for the key reader?
sorry about all the questions.
snowy2
posted on 2/4/17 at 06:50 AM Reply With Quote
you dont need the PAS or A/C but you may need to earth out the wires (or not) give your self the choice some ECU's need to have them earthed out to keep the idle steady.
like wise the EGR and fuel vapour purge valve and crankcase breathers (vent to atmosphere via catch tank) all are bin fodder.
you need the air flow sensor the throttle body the temp sensor is behind the alternator you need that, it controls everything on the Focus (ecu, temp gauge and cooling fan) then there is the cam position sensor, oil pressure switch, and crank sensor. last of all you need the first lambda (green plug) the second (purple plug) is only needed if you keep the cat.
if you reuse the ford injectors they come with most of the engine sensors your keeping on its loom you will just have to extend the wires for the TPS and AFS
letting the ECU control the cooling fan is simplicity its self. the ford cooling fan relay is just a high power standard relay with an extra terminal (numbered 7) this pin connects to earth, its for an anti spike diode.....when the fan switches off it will send a large voltage back to the ECU unless the diode is fitted, (this can destroy the ECU if not fitted.) the ECU switches on the fan by earthing it via pin 13 (ECU)
ooh dont forget the idle control valve...it need to get its air supply from between the TPS and the AFS, the ECU need to get a signal from the AFS to keep the car running
[Edited on 3/4/17 by snowy2]
package626
posted on 2/4/17 at 06:59 AM Reply With Quote
sweet got ya.
and what about the key reader pins? do you know what they are?
snowy2
posted on 2/4/17 at 07:01 AM Reply With Quote
the key reader is the PATS system.....listed on my hand drawn diagram....your right the no3 injector is missing, i will look and report back.
