Author: Subject: Type 9 gearbox conversion to electronic speedo
Schrodinger
posted on 25/6/17 at 10:30 AM Reply With Quote
I'm wanting to convert my t9 gearbox to drive an electronic speedo I have had a search on hear and itseems revotec used to do a drive but I cannot find anything on their website. Has anybody any other suggestions as to suppliers, I do not want to use magnets or other contraptions attached to the prop shaft as I have found them quite unreliable in the past.
Keith
Aviemore
Pete Jordan
posted on 25/6/17 at 10:47 AM Reply With Quote
Carbuilder solutions have an electronic speedo sensor (see link) and also sell an adaptor plate to allow it to fit into the type 9 speedo cable fitting. Obviously whether this sensor will work for you depends on which speedo you are fitting.
Speedo sensor
Adaptor for type 9
I hope that helps.
Pete
avagolen
posted on 25/6/17 at 12:20 PM Reply With Quote
There is a way if you can find the part.
Some sierra's had an electronic pickup that was used for EFI.
It needs a different speedo drive gear as the electronic drive goes from the rear of the normal cable drive.
If gives 5 pulses for 2 rotations of the gearbox output shaft.
Give Steve a call at BGH. He supplied both the gear and the sensor for me.
Hope that helps.
Ugg10
posted on 25/6/17 at 04:23 PM Reply With Quote
http://www.burtonpower.com/revotec-electronic-speedo-adaptor-ford-gearbox-revt9-a.html
You can then add a speed sensor from a Puma/Focus. I have the wave form and pin outs if needed for these encoders.
Most electronic speeds also your with a couple of magnets and a sens on the hub/prop/diff flange. The ETB Digidash lite manual (download form their website) has pictures of this type and the sensors/magnets are available form them.
[Edited on 25/6/17 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Schrodinger
posted on 25/6/17 at 07:19 PM Reply With Quote
Thanks for that chaps
Keith
Aviemore
posted on 26/6/17 at 02:45 PM Reply With Quote
Doesn't one from any ford fwd gearbox screw on with the threaded adapter?
