Author: Subject: High Pressure Oil Pump - Pinto
RobBrown
posted on 14/10/17 at 04:54 PM Reply With Quote
Hi Guys,
It's been a while...
I rebuilt the pinto bottom end after having the crank reground (rattle on #4 cylinder), so took the opportunity to do as much as I could.
I purchased a high pressure oil pump and fitted it as it seemed to be the recommendation from numerous forum topics to make sure that oil circulated better around the engine.
When everything was back and fully assembled I was pleased that the engine sounded sweet and the rattle from the worn crank had disappeared, but noticed oil leaking from the head gasket at the front of the engine.
I then checked the rad and the tell tale signs of a blown head gasket - creamy sludge in the water
All head bolts were torqued down to the manual spec, so my question - is a high pressure oil pump the cause here.
Should I have been fitting a different gasket?
I now need to strip it back again with a new gasket, so just want to make sure I don't end up in the same position again.
Rob
snapper
posted on 14/10/17 at 07:09 PM Reply With Quote
High pressure pump is not the problem
Check it's not oil leaking from rocker cover and if not then you need to check how flat the block and head faces are
I eat to survive
I drink to forget
RobBrown
posted on 14/10/17 at 07:25 PM Reply With Quote
Definitely from the gasket and plenty of oil in the water to suggest a head gasket failure.
I've got to take it off anyway to replace the gasket so will check that.
I'm hoping it will be obvious when the head comes off.
Rob
RobBrown
posted on 15/10/17 at 08:39 PM Reply With Quote
not sure what this proves
gasket
gasket
Oil in the water, but oil is clean.
No obvious signs on the gasket that the 2 have crossed over.
Seems to imply a failure in the engine elsewhere - Do you agree?
daviep
posted on 15/10/17 at 09:01 PM Reply With Quote
Do you have an oil to water oil cooler?
RobBrown
posted on 15/10/17 at 09:04 PM Reply With Quote
No, just a standard pinto.
Dick
posted on 16/10/17 at 08:19 AM Reply With Quote
If you have not moved the gasket it looks badly out of aline
RobBrown
posted on 16/10/17 at 09:59 AM Reply With Quote
Yes, it moved when I removed the head.
The bolts would have kept it in line when fitted.
RobBrown
posted on 16/10/17 at 10:05 AM Reply With Quote
What I did notice is that the sludge is worse at the front, then at the back, indicating an issue around #1 and #2 cylinder.
Feeling like a cracked block around #1 and #2.
May end up getting a new block as I don't want to spend much more time and money putting it all back together only to find the issue re-occurs.
Is there anyway of diagnosing a cracked block?
