Author: Subject: Headlight question.
tompat3463
posted on 23/2/18 at 06:48 PM Reply With Quote
Headlight question.
For Iva purposes. Does the dipped beam stay on when you activate full beam ? Or does dipped switch off when you activate full
Alan
gremlin1234
posted on 23/2/18 at 08:06 PM Reply With Quote
it can do either, unless it's gas discharge, when dip usually has to stay on with beam
secn 25 headlamps rs 9
Gas Discharge and LED Headlamps
9. Must be accompanied by evidence of compliance with the technical requirements if not compliant with the following:
. is "E" or "e" marked
. dipped beam remains on when main beam is on (gas discharge only)
. is fitted with a wash system (see Notes 2 and 4)
. is fitted with an automatic headlamp self levelling system or self levelling suspension (see Note 3)
edit, though be careful with normal halogen headlights as they are likely to overhead if both filaments are on for any significant time
[Edited on 23/2/18 by gremlin1234]
adithorp
posted on 23/2/18 at 08:34 PM Reply With Quote
With a twin filament you'd only have one on at a time. Both together will overheat and blow the bulbs pretty quick. Only time you'd nomally have both is if you use the headlight flash (normally wired to main) while the dip is on.
As far as IVA is concerned, there's no requirement one way or the other as far as I'm aware.
http://jpsc.org.uk/forum/
snowy2
posted on 25/2/18 at 05:04 PM Reply With Quote
normally dip beam goes off when main beam on....
sometimes you are the pigeon, most of the time the statue.
snowy2
posted on 25/2/18 at 05:09 PM Reply With Quote
Construction and use regulations
always refer to these when i am building a car.
Mr Whippy
posted on 26/2/18 at 12:36 AM Reply With Quote
Enough to sap the soul from any car builder......
