Author: Subject: Best edge trim for tight radius and 1.2mm panel
TimC
posted on 8/4/18 at 05:48 PM Reply With Quote
Hi all,
Anyone recommend anything specific to basically act like an open grommet on a 40-odd mm hole in an aluminium panel?
Ta
[Edited on 8/4/18 by TimC]
James24785
posted on 8/4/18 at 07:57 PM Reply With Quote
I've got some quite small rubber "U" trim I've used on mine. Can send ya bit thru the post to try?
obfripper
posted on 8/4/18 at 09:33 PM Reply With Quote
VW part 1J0827417 is a 2 part blanking plug that would probably do the trick, it's approx 40-50mm off hand.
From a mk4 golf, mk5 polo and all the related cars.
Dave
harmchar
posted on 8/4/18 at 09:41 PM Reply With Quote
There's stuff on eBay called Neoprene blow hole rubber.
Any use?
TimC
posted on 9/4/18 at 09:50 AM Reply With Quote
And the same to you!
Thanks all,
