Author: Subject: Single pole switches for lights
David_17
posted on 12/5/18 at 08:10 PM Reply With Quote
Hi. It's been a few years since I've posted on here. Sold my Haynes roadsters a few years ago.
Anyway, on with a new project now and up to the wiring stage.
I've got some flush mounting single pole switches for my lights, if I have the side lights wired to one switch and the dipped beam on a separate switch is this ok for IVA? Or do the side lights have to come on with the dipped beam?
I can't find it saying one or the other in the IVA manual. Can anyone help?
Dave
furryeggs
posted on 12/5/18 at 08:37 PM Reply With Quote
The side lights should stay on with dip beam.
David_17
posted on 12/5/18 at 08:39 PM Reply With Quote
Thanks for the reply. That's what I assumed, but is it actually in the iva manual anywhere? I can't see it...
[Edited on 12/5/18 by David_17]
cliftyhanger
posted on 12/5/18 at 09:16 PM Reply With Quote
Needs thought about tail lights.
If you use 2 switches, then you will need to use diodes to stop the dipped beams coming on when you switch the sidelights.
Plan b may be to use the sidelight switch to power up the dipped beam switch. (then relays for the actual dipped and indeed main beams.
David_17
posted on 12/5/18 at 09:34 PM Reply With Quote
Yea. My dipped beam relay can take care of that. I'll just feed the 12v to the coil from the side lights and use the dipped beam switch on the relay coil earth
