Author: Subject: 6m Skirting board
femster87
posted on 26/6/18 at 11:11 AM Reply With Quote
6m Skirting board
Hi Guys, Bit of a diy question. Does anyone know a company that makes skirting boards in 6m lenghts?
posted on 26/6/18 at 12:10 PM Reply With Quote
Can't say I do, but last time I fitted new skirting I joined sections by cutting mating 45 bevels on each end. Once glued on the wall and painted over you can't see the joint.
Slimy38
posted on 26/6/18 at 12:13 PM Reply With Quote
I've only ever found 2.4m, which means that for the rooms that are longer we've had to join them. As Nick mentions, a 45 degree join is almost invisible.
Having said that, even at 2.4m they're really difficult to work with, I've had a couple twist and crack because they can't hold their own weight. I'd imagine 6m is even worse?
mac1ZR
posted on 26/6/18 at 12:50 PM Reply With Quote
Think MDF comes in 5metre lengths, but timber is usually 4.8 metres
View User's Profile E-Mail User View All Posts By User U2U Member This User Has MSN Messenger
femster87
posted on 26/6/18 at 01:35 PM Reply With Quote
Room is 5.6 meters. I have found 5.4m but not 6. As you said, it would be a nightmare to handle. I just dont want multiple joints
posted on 26/6/18 at 02:25 PM Reply With Quote
Worth mentioning that the stuff I used was pre-primered MDF - double faced with a different profile either side.
HowardB
posted on 26/6/18 at 04:02 PM Reply With Quote
same 5m MDF pre-primed from a timber yard,.. silly cheap compared with real wood too
Howard
posted on 27/6/18 at 11:31 AM Reply With Quote
The pre-primed MDF cuts nicely and paints easily as well.
I've found real wood a PITA before as it needs knot treatment, primer and then top coat. Real wood is often warped along its length as well, making it harder to get a good straight finish.
harmchar
posted on 27/6/18 at 09:29 PM Reply With Quote
I bought pvc skirting at 6m from Eurocell. Never shrinks, cracks, twists, never needs painting. Wipe clean and forget. Will never go back to white gloss wood again.
