Author: Subject: Koso Digidash
CTLeeds
posted on 22/10/18 at 01:47 PM Reply With Quote
Koso Digidash
Hi all,
Does anyone have any experience using KOSO Digidashes at all. I bought a small DB-01RN to position on top of the steering wheel cowl in the gap inside the top of the steering wheel and all functions are working bar the tacho. I've got it connected to the wire that went to the stock tacho and I've been through numerous settings on the dash with no joy.
Any clues anybody?
Chris
CosKev3
posted on 22/10/18 at 02:52 PM Reply With Quote
I think some OE tacho signals are not compatable?
In the instructions with my Koso it shows you three IIRC ways to connect the tacho?
CTLeeds
posted on 22/10/18 at 02:59 PM Reply With Quote
Thanks Coskev. I think the BMW tacho signal should be okay. I've measured it as a 5v pulse train which should be usable. The supplier suggested wrapping a wire round the top of the coil pack straight to the dash to see if that worked but I haven't tried it yet and it sounds a bit 'agricultural' for my liking. The instructions suggest that connecting directly to the BMW wire should work (although it refers to a BMW bike rather than car...)
Chris
CosKev3
posted on 22/10/18 at 03:03 PM Reply With Quote
Can you alter hi/lo etc in the settings on the dash?
Mines a bigger clock than yours,seem to remember quite a few options in the tacho settings
CTLeeds
posted on 22/10/18 at 03:20 PM Reply With Quote
There is a Hi/Lo option although I'm not sure what it refers to...?
CosKev3
posted on 22/10/18 at 03:34 PM Reply With Quote
Looking in my instructions Hi Is for positive input,Lo is for negative input.
CosKev3
posted on 22/10/18 at 03:40 PM Reply With Quote
If you want a pic of my instructions U2U your email,just tried uploading a pic but it won't let me as must be too big
CTLeeds
posted on 23/10/18 at 09:27 AM Reply With Quote
Hi Coskev,
I'll give the Hi/Lo thing a go and see if that helps. Failing that I'll definitely get in touch for your diagram.
Thanks for the help,
Chris
CTLeeds
posted on 30/10/18 at 07:12 PM Reply With Quote
Coskev,
Got it going. It was the hi/lo thing. Thanks for your help.
Regards,
Chris
CosKev3
posted on 31/10/18 at 12:22 PM Reply With Quote
Nice one
