Author: Subject: BEC reverse gear and MOT
Norfolkluegojnr
posted on 2/11/18 at 04:40 PM Reply With Quote
Hi Guys,
haven't posted in a while - i'm looking at a fellow members car at the weekend and wanted to sanity check something.....
R1 BEC car, which originally had a reverse box but has since had it removed, so no reverse gear currently. If memory serves, this is fine for MOT purposes? Reverse isn't checked for MOT?
Secondly, it still has a reverse light fitted to the rear. would I need to remove this for MOT? I believe if a light is fitted it needs to work?
Any help greatly appreciated!
40inches
posted on 2/11/18 at 09:21 PM Reply With Quote
No reverse needed for MOT. However if the reverse light is fitted, it will be tested. I think
loggyboy
posted on 2/11/18 at 11:26 PM Reply With Quote
Reversing lamps are need on post 2009 cars in new mot. So d3p3nds on if you have a q or a post 2009 age plate. Reverse itself is still not required i believe.
Mistral Motorsport
Norfolkluegojnr
posted on 5/11/18 at 09:33 AM Reply With Quote
Its a J plate, so no issues there.
Thanks for your help guys.
