Author: Subject: Small form alternator
Shooter63
posted on 27/1/19 at 10:41 AM Reply With Quote
Hi guys
I'm looking for a small(er) form alternator, something like a Bedford rascal type will do, it's to go on my zetec, I was going to use the original one but it hits the underside of the inlet manifold now I've removed the bodge that was on before.
Shooter
big_wasa
posted on 27/1/19 at 04:21 PM Reply With Quote
I posted a few years ago about the Suzuki Gsf600 and 1200. Some use a 40a Denso. I’ve just got around to doing mine for my current project.
They differ from the car type on how they mount and how the drive fits ie a tapered shaft. If you have a lathe it’s easy to turn the Cush basket into a bush for a standard 17mm pulley. I’ve gone for an 80mm pulley from a Sierra cvh.
eBay is hit and miss, the last two I bought where a tenner plus’s postage ( that’s a genuine Denso not a knock of.
I’ve also shaved the front cover and fitted a reverse impeller and pulley for a very clean and simple triangle form.
The bracket is very basic but since the photo I’ve added a brace to the front.
eBay Item
ken555
posted on 27/1/19 at 04:45 PM Reply With Quote
suzuki swift alternator is pretty small.
Part no is dra3337
eBay Item
[Edited on 27-1-19 by ken555]
starterman
posted on 28/1/19 at 04:27 PM Reply With Quote
If you want a new 40 amp small one let me know.
Mike
DavidW
posted on 29/1/19 at 09:27 AM Reply With Quote
I've got one of the small Denso ones and its great.
I'm just swapping from a silvertop to a blacktop so have the retro ford silver top bracket if needed?
posted on 29/1/19 at 04:45 PM Reply With Quote
Believe it was a Denso one I fitted to my Pinto engined MK Indy (donor Sierra alternator was too large)...
[img][/img]
