Author: Subject: Zetec, Haynes Header Tank
the_big_1
posted on 29/8/19 at 06:34 PM Reply With Quote
Hi guys,
I am in the middle of my Haynes 2.0l Zetec build
What coolant expansion / header tanks have you used?
What size would you go for and any particular OEM.car ones that are good?
Many thanks!!!!
pmc_3
posted on 29/8/19 at 08:29 PM Reply With Quote
Mk2 Clio one is easy to mount
View User's Profile View All Posts By User U2U Member This User Has MSN Messenger
the_big_1
posted on 29/8/19 at 08:37 PM Reply With Quote
Yeah that looks good. Guess all I would need to do is t the two bleed pipes, one from thermostat housing, other from radiator top, together just at the single entry to the expansion bottle?
pmc_3
posted on 29/8/19 at 08:57 PM Reply With Quote
Most of them have two outlets, one at the top and one at the bottom.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A% 2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F303231225683
Bottom outlet teed in to bottom hose on the rad and then the bleeds in to the top outlet
[Edited on 29/8/19 by pmc_3]
the_big_1
posted on 29/8/19 at 09:00 PM Reply With Quote
That's the ones I spotted. Bottom outlet to bottom hose, t top outlet to the two bleed pipes and should be good
pmc_3
posted on 29/8/19 at 09:20 PM Reply With Quote
Yep, had just edited my post to say the same!
the_big_1
posted on 29/8/19 at 09:22 PM Reply With Quote
Lol great minds and all that, many thanks, looks like a plan!
pmc_3
posted on 29/8/19 at 09:24 PM Reply With Quote
The other one a lot of people use is the round header tanks fitted to most vws, mounting isnt quite as easy.
the_big_1
posted on 29/8/19 at 09:26 PM Reply With Quote
I did see them online but as you say, struggling for an easy way to mount it
big_wasa
posted on 30/8/19 at 06:30 AM Reply With Quote
I am currently looking at the bmw mini tank for my next one as well as the vw and Renault tanks.
[Edited on 30/8/19 by big_wasa]
40inches
posted on 30/8/19 at 07:39 AM Reply With Quote
I used the Renault tank, very cheap new eBay Item
No problem with the 3litre V6, and works if it is lower than the rad top.
Robbaa
posted on 1/9/19 at 08:25 AM Reply With Quote
not strictly a haynes but my zetec blacktop uses a Vauxhall cavalier tank
