Author: Subject: BEC Electric reverse help
john77cars
posted on 31/10/19 at 01:03 PM Reply With Quote
Ive got a mac#1 motorsports with a zx10r engine.....im after fitting a electric reverse to it! It has a landrover freelander diff fitted and was seeing if anyone one here knows if theres a kit that would fit this? Thanks.
[Edited on 31/10/19 by john77cars]
CosKev3
posted on 31/10/19 at 06:26 PM Reply With Quote
Most people only fit them to pass the IVA,then remove them.
In all honesty they are a waste of time,they will only move the car on flat,or slight inclines.
Over 4 years of running my BEC the couole of times I needed a reverse,meeting tractors down lanes etc,I couldn't use it as the road was not flat!
So still had to get out and push it
john77cars
posted on 31/10/19 at 06:33 PM Reply With Quote
Thanks! I have to fit one as I do hill climb with it! The championship im doing next year says I have to have a reverse.
CosKev3
posted on 1/11/19 at 09:59 AM Reply With Quote
Ah that's a pain,will they check it works?
It's not a easy fitment if your chassis doesn't have the mounting points welded on already.
john77cars
posted on 1/11/19 at 10:13 AM Reply With Quote
Yeah they will check it! I don't mind fitting it if there's somone who does a kit that will fit the freelander diff flange?
CosKev3
posted on 1/11/19 at 01:05 PM Reply With Quote
Getting a flange made is probably the easiest part tbh!
Getting a motor mounted to the chassis is the hardest job,moving fuel/brake pipes etc to weld on brackets.
40inches
posted on 1/11/19 at 03:22 PM Reply With Quote
Westgarage used to do a kit that fitted on the engine for FE/RWD bike engine setups.
May be worth an email? https://chaindrivediff.co.uk/product-category/other-products/electric-reverse-units/
john77cars
posted on 1/11/19 at 03:57 PM Reply With Quote
Thanks! I'll give them a try.....there must be someone on here that fitted one with a freelander diff?
