John
posted on 23/10/02 at 12:02 AM |
Overall Length
I am using a sierra for running gear including IRS as per Avon. I was wondering if it is necessary to cut down propshaft? Is it not possible to
increase length of car to match sierra prop shaft length exactly.
If I do have to cut down the propshaft is it really necessary to have it done professionally, as advised by Tiger book, and balanced? Or can this be
done in my own workshop with care (no lathe but do have 14in chop saw)?
Thanks for any advice on this.
John.
Working on a CVH 1.8 engined Locost. Hoping to use as much as possible of Sierra donor. £210 left.
posted on 23/10/02 at 07:44 AM |
John,
I'm not going to tell you not to do your own propshaft - but consider the following:
The propshaft is around 2.5 feet long, weighs around 5 - 10 lbs, and at full speed is going to be spinning at 7000rpm. Just consider what will happen
to the propshaft tunnel if your welding lets go - and your legs are just alongside.
Even if your work holds together OK, there is still the problem of balancing - a small imbalance will cause a fair amount of vibration.
Many have modified their own propshafts, and I'm sure that many are working really well and have given their owners good service... but this was one
component that I decided to buy in ready-made!
regards,
(who lowers his head behind the parapet and waits for the missiles!)
James
posted on 23/10/02 at 09:34 AM |
quote: Is it not possible to increase length of car to match sierra prop shaft length exactly.
Hi John,
If you want it to be long enough to be a 4 seater!
From what I remember my Sierra prop is about 4/5 feet long. The Locost one needs to be about 18 inches so you're talking about adding 3 feet to the
length of your chassis!
Even if you thought that a good idea then the complexity/cost/effort involved in extending the car this much is bound to be more effort than getting
the prop professionally chopped I'd have thought.
HTH,
James
Reminds me of a conversation I had with a colleague the other day. I mentioned to him there's no plans for IRS around so that I was designing my own.
He suggested that instead I used a cut down Sierra chassis and bolted my body panels to that! ![](/images//smilies/shocked.gif)
stevedenbigh
posted on 23/10/02 at 10:35 AM |
quote: Originally posted by James
quote: . He suggested that instead I used a cut down Sierra chassis and bolted my body panels to that!
Isn't that what ford did with there Escort Cosworth?
chrisg
posted on 23/10/02 at 05:15 PM |
As I am 6 feet tall I estimate the length of my overalls to be about 5 feet 2inches.
Thankyou
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Liam
posted on 23/10/02 at 06:47 PM |
quote: Isn't that what ford did with there Escort Cosworth?
Yeah it is. Not sure that tactic would work for a seven replica though!
paulbeyer
posted on 23/10/02 at 09:39 PM |
Not unless you want to drive around in a Robin Hood.![](/images//smilies/bigsmile.gif)
stevedenbigh
posted on 24/10/02 at 09:53 AM |
Of Loxley
Speaking of the man from sherwood forest, I seem to remember they has an add campaign asking "is this the most beutiful chassis ever". Where do I
send my answer "no, and it lacks proper triangulation" to?
John
posted on 26/10/02 at 01:14 AM |
Thanks all for help.
I didn't realise there was so much difference in length of prop shaft. Leaving without cutting down is not now an option.
John.
