Author: Subject: Help with dials/dash
mad_skillz
posted on 12/11/02 at 07:13 PM Reply With Quote
Can i use any dash or dials from any car? Will they have to be recalibrated, if so how much does it cost? thanks very much
stephen_gusterson
posted on 12/11/02 at 07:45 PM Reply With Quote
Thats like saying can i run to work and if so how long will it take me. I dont know where you work or how fat you are etc.
However......
There is no such thing as 'standard' bits for speedos and dials.
Some are mechanical, some are electronic.
Generally, tachos are electronic.
Speedos are mechanical and electronic. After market electric ones are adjustable, the ones fitted as std are not. Mechanical ones can be tweaked at specialists.
Water temp and voltmeters (duh) are electronic.
Oil guages are eother pressure or electronic.
Specific guages need specific sensors - you cant mix and match.
Your cheapest route is to use the dash components from the donor. Wont look as good, but you could set the bits from a sierra behind a hole in the dah with a suitable bezel - this is what robin hood do on the 2b.
Buying nice instruments will cost 250 - 400 quid. However, as you are gonna be staring at the dash a lot, it should look the part. I spent 323 on mine, plus 60 quid for a walnut panel. But then my builds been 0ver 3000 quid so far.
atb
PS
As well as looking in old triumphs, some OLD skodas / ladas have round instruments - you might want to take a look at a scrappy.
View User's Profile E-Mail User View All Posts By User U2U Member This User Has MSN Messenger
mad_skillz
posted on 12/11/02 at 08:05 PM Reply With Quote
i found a ferrari 131 dash and was wondering if it could go with my sierra?
Thanks Again
cunny
posted on 12/11/02 at 08:15 PM Reply With Quote
i used to be able to do the 100 m dash but if i get a runny nose now im knackered
stephen_gusterson
posted on 12/11/02 at 11:11 PM Reply With Quote
why would you want to downgrade your sierra?
mad_skillz
posted on 13/11/02 at 06:54 PM Reply With Quote
im using the sierra as my donor car for my locost, and a escort mk2 rear axle
Alex
bsilly
posted on 13/11/02 at 07:09 PM Reply With Quote
if i found some ferrari clocks ...i would mabye try to transfer the guts of the sierra speedo in to ferrari..tacho might be alright...but nowt stoppin yer trying to do same.. end up with ferrari looks with sierra workins ......its worth a try.....if it was made by a bloke it can be changed by a bloke.....let me know whatt you think..
mainly digger drivin me
